Intel® FPGA University Program
University Program Material, Education Boards, and Laboratory Exercises
1238 Discussions
write .bmp on sd card by ip sd card controller
Hi all!
I'm doing a project about " write.bmp from camera to sd card by use de2 board" i use IP Controller Sd card and I have some problem about my project:
- I interface DE2 board with Camera. it's Ok
- image is stored on Sdram and i use Sram buffer to display on Vga. it's Ok
-But when i write .bmp to on Sdcard. it's not Ok. I check sdcard. I see filesize of image, but i can't open that image.( maybe i write wrongly)
Give me some help, please..
my code:
//================# include <io.h># include <system.h># include <stdio.h># include "gui.h"# include "altera_up_sd_card_avalon_interface.h"
struct image images[MAX_NUM_IMAGES];
struct image *current_image;
struct image *prev_image = NULL;
int num_images = 0;
int current_image_num = 0;
short int file_handle1;
char name1[] = "filexx.bmp";
// send image on Sdram to Sram_frame_buffer
void send_image(int direction)
current_image = (direction == 2) ? current_image->next :
current_image->prev;
printf("current image: %d\n", current_image->image_num);
int i = current_image->image_num;
printf("sending image\n");
unsigned char byte_r, byte_g, byte_b;
int pixel;
int x, y;
int x_start = 0;
int x_end = IMG_X_SIZE;
int x_inc = 1;
for (x = x_start; x < x_end ; x += x_inc)
for(y = 0; y < IMG_Y_SIZE; y += 1)
// send request
IOWR_16DIRECT(TV_TO_VGA_0_BASE, 16, 1);
// set requested x and y positions
IOWR_16DIRECT(TV_TO_VGA_0_BASE, 10, x);
IOWR_16DIRECT(TV_TO_VGA_0_BASE, 12, y);
// get pixel from memory
byte_r = saved_images[0][y][x];
byte_g = saved_images[1][y][x];
byte_b = saved_images[i][2][y][x];
if (num_images == 0)
pixel = 0;
else
pixel = ((byte_r >> 3) << 11) | ((byte_g >> 2) << 5) |((byte_b >> 3) << 0);
// send pixel
IOWR_16DIRECT(TV_TO_VGA_0_BASE, 14, pixel);
// reset request
IOWR_16DIRECT(TV_TO_VGA_0_BASE, 16, 0);
printf("sent\n");
void save_image() //== store image on sdram
num_images++;
int pixel;
int x, y;
// find next free slot
int i;
for (i = 0; i < MAX_NUM_IMAGES; i++)
if (!images.is_taken)
current_image = &images
break;
if (prev_image == NULL)
current_image->prev = current_image;
current_image->next = current_image;
else if (num_images == 2)
prev_image->prev = current_image;
prev_image->next = current_image;
current_image->prev = prev_image;
current_image->next = prev_image;
else if (num_images >= 3)
current_image->next = prev_image->next;
prev_image->next->prev = current_image;
current_image->is_taken = 1;
current_image->image_num = i;
prev_image = current_image;
printf("saving image: %d/%d\n", i, num_images);
for (y = 0; y < IMG_Y_SIZE; y += 1)
for(x = 0; x < IMG_X_SIZE; x += 1)
// send request
IOWR_16DIRECT(TV_TO_VGA_0_BASE, 4, 1);
IOWR_16DIRECT(TV_TO_VGA_0_BASE, 0, x);
IOWR_16DIRECT(TV_TO_VGA_0_BASE, 2, y);
// get pixel data
pixel = IORD_16DIRECT(TV_TO_VGA_0_BASE, 6);
// enter pixel data into image matrix
byte_r = (unsigned char) (((pixel >> 11) & 0x1F) << 3);
byte_g = (unsigned char) (((pixel >> 5) & 0x3F) << 2);
byte_b = (unsigned char) (((pixel >> 0) & 0x1F) << 3);
// save pixel
saved_images[0][y][x] = byte_r;
saved_images[1][y][x] = byte_g;
saved_images[i][2][y][x] = byte_b;
printf("saved\n");
printf("number of images: %d\n", num_images);
my code:
//==========================write image on sd card
void write_image(int number)
char i = number;
char h = 0;
bool create, hum ;
int x, y,j, c;
alt_up_sd_card_dev *device_reference = NULL;
int connected = 0;
device_reference = alt_up_sd_card_open_dev("/dev/SD_Card_0");
if (device_reference != NULL)
if ((connected == 0) && (alt_up_sd_card_is_Present()))
printf("Card connected.\n");
if (alt_up_sd_card_is_FAT16())
printf("FAT16 file system detected.\n");
else
printf("Unknown file system.\n");
connected = 1;
else if ((connected == 1) && (alt_up_sd_card_is_Present() == false))
printf("Card disconnected.\n");
connected = 0;
//==============define header==============
unsigned char BITMAP_HEADER[] = {
0x42, 0x4D, 0xB6, 0x91, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x36, 0x00, 0x00, 0x00, 0x28, 0x00,
0x00, 0x00, 0x50, 0x01, 0x00, 0x00, 0xE8, 0x00, 0x00, 0x00, 0x01, 0x00, 0x18, 0x00, 0x00, 0x00,
0x00, 0x00, 0x70, 0xAD, 0x00, 0x00, 0xEB, 0x0A, 0x00, 0x00, 0xEB, 0x0A, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00
printf("Bitmap header size is %d\n", (int) sizeof(BITMAP_HEADER));
int file_size = (IMG_X_SIZE1*IMG_Y_SIZE1) * 3 + sizeof(BITMAP_HEADER);
// write byte 0 (LSB)
BITMAP_HEADER[FILE_SIZE_OFFSET+0] = (file_size >> 0) & 0xFF;
// write byte 1
BITMAP_HEADER[FILE_SIZE_OFFSET+1] = (file_size >> 8) & 0xFF;
// write byte 2
BITMAP_HEADER[FILE_SIZE_OFFSET+2] = (file_size >> 16) & 0xFF;
// write byte 3 (MSB)
BITMAP_HEADER[FILE_SIZE_OFFSET+3] = (file_size >> 24) & 0xFF;
printf("Bitmap file size: %02X %02X %02X %02X\n",
BITMAP_HEADER[FILE_SIZE_OFFSET+0],
BITMAP_HEADER[FILE_SIZE_OFFSET+1],
BITMAP_HEADER[FILE_SIZE_OFFSET+2],
BITMAP_HEADER[PIXEL_WIDTH_OFFSET+0] = (unsigned char)((IMG_X_SIZE1 >> 0) & 0xFF);
// write byte 1
BITMAP_HEADER[PIXEL_WIDTH_OFFSET+1] = (unsigned char)((IMG_X_SIZE1 >> 8) & 0xFF);
// write byte 2
BITMAP_HEADER[PIXEL_WIDTH_OFFSET+2] = (unsigned char)((IMG_X_SIZE1 >> 16) & 0xFF);
BITMAP_HEADER[PIXEL_WIDTH_OFFSET+3] = (unsigned char)((IMG_X_SIZE1 >> 24) & 0xFF);
printf("Bitmap width: %02X %02X %02X %02X\n",
BITMAP_HEADER[PIXEL_WIDTH_OFFSET],
BITMAP_HEADER[PIXEL_WIDTH_OFFSET+1],
BITMAP_HEADER[PIXEL_WIDTH_OFFSET+2],
BITMAP_HEADER[PIXEL_HEIGHT_OFFSET+0] = (unsigned char)((IMG_Y_SIZE1 >> 0) & 0xFF);
// write byte 1
BITMAP_HEADER[PIXEL_HEIGHT_OFFSET+1] = (unsigned char)((IMG_Y_SIZE1 >> 8) & 0xFF);
// write byte 2
BITMAP_HEADER[PIXEL_HEIGHT_OFFSET+2] = (unsigned char)((IMG_Y_SIZE1 >> 16) & 0xFF);
BITMAP_HEADER[PIXEL_HEIGHT_OFFSET+3] = (unsigned char)((IMG_Y_SIZE1 >> 24) & 0xFF);
printf("Bitmap height: %02X %02X %02X %02X\n",
BITMAP_HEADER[PIXEL_HEIGHT_OFFSET],
BITMAP_HEADER[PIXEL_HEIGHT_OFFSET+1],
BITMAP_HEADER[PIXEL_HEIGHT_OFFSET+2],
//========open file to write bitmap=====
name1[4] = h/10 +48;
name1[5] = h%10 +48;
file_handle1 = alt_up_sd_card_fopen(name1, create);
if (file_handle1 == -1)
printf("file could not be open.\n");
else if ((file_handle1 == -2))
printf("file be already.\n");
else
printf("file be open.\n");
if (create == true)
printf("file be create .\n");
//=========write header=============
for (j=0; j<54; i++)
alt_up_sd_card_write( file_handle1, BITMAP_HEADER[j]);
printf("write header.\n");
//============write data=================
for (y = 0; y < IMG_Y_SIZE1; y += 1)
printf(".");
for(x = 0; x < IMG_X_SIZE1; ++x)
for (c = 2; c >= 0; c--)
alt_up_sd_card_write( file_handle1, saved_images[i][c][y][x]);
//printf("file be write .\n");
printf("\nDone!\n");
hum = alt_up_sd_card_fclose(file_handle1);
if (hum == true)
printf("file be close.\n");
if (h <100)
h++;
return 0;
Because, First I post document on forum, so i have some mistakes..
I have to post my code more once. hic.
Ok..Please, You help me? Thanks so much
could you please provide the link or the program files you have interfaced the sdcard for storage. I am working on the same project now.
