0xc000007b Error
Valerio_F_
I'm moving my sw from old Visual C++ to Visual Studio 2015 in Windows Seven environment. My sw is written in C plus Fortran (INTEL 7.0 compiler) to interface with IMSL (7.0) library. No problem in recompiling it and running on my developing PC. When I move to another PC with 32 bit release I get this error: 0xc000007b Unfortunately my sw has to run on a industrial PLC that supports only 32 bit code. I suppose I'm using IMSL in dll mode becausethe application needs imsl_dll.dll to run. I tried to avoid the problem linking in statically mode (to be honest this way is not recommended) but i didn't find the way to avoid a lot of unresolved symbols. Thanls in advance
andrew_4619
So many possible causes.... rather than have us make scattergun guesses, do a full build and post the buildlog. That should give some clues.
Lorri_M_Intel
Also, if you are opening files, check the filenames in your program.
Steve_Lionel
That error is "unable to start", meaning that Windows is refusing to run the application at all.  Is the target system running Windows XP by any chance? If so, see https://software.intel.com/en-us/articles/linking-applications-using-visual-studio-2012-to-run-on-windows-xp
By the way, I assume you meant version 17.0.
Valerio_F_
Target Platform is Seven for both (developing and run). Which building log file have I to post?
andrew_4619
BuildLog.html found in the output folder
Valerio_F_
Found only this log file
andrew_4619
You are building some add on for an MSC analysis by the look of it this seems to be a log of scripts from that? Not sure where to go with this.....
Steve_Lionel
Wow, those MSBUILD logs are nearly impossible to read... Of course, this showed only the C++ side, but I doubt seeing the Fortran logs would be helpful.
Would you please set the linker option to generate a map file, relink, then attach a ZIP of the .map file to a reply here? I'm guessing that the static code and data is close to or greater than 2GB, which can trigger this error. At first I thought the use of /STACK:"20000000" in link options might be an issue, but that's only 20MB and unlikely to cause a problem.
