11.1 Windows Integration
ferrad01
Just installed IVF 11.1 under VS2008. One issue:
I regularly use Tools -> Attach to Process, and I'm used to this being the first option in the drop down. Now Intel 11. has stolen this position in the list with "Intel Visual Fortran Module Wizard", which I don't use. Is it possible to remove this from the Tools dropdown or at least move it from top position?
ferrad
Kevin_D_Intel
You can rearrange the tool selections as follows:
1. Select Tools > Customize and then click Rearrange Commands
2. Left-Click the Menu Bar radio button (left-side), then select Tools from the selection pull-down (right-side).
3. Left-Click (to highlight) Intel Visual Fortran Module Wizard (if not already highlighted), then click Move down.
4. Click Close, and Close again.
Your Tools menu should now show the order you desire.
Kevin_D_Intel
ferrad01
Excellent! Thanks for your help.
