PRINT and WRITE to a common file
longden_loo
I have a large legacy app with a mixture of PRINT and WRITE statements, the latter in different forms, sometimes WRITE(*,*) and other times the unit number is given (ie, WRITE(6,*)).
Previously these messages were displayed in a console window and the order of the output was as expected ... in the order of occurrence during execution.
However, when the app was converted to a DLL, the output needed to be rerouted to a file for use as a runtime log, so I initialized units 6 and -1 to a file of the same name using OPEN. This resulted in a jumbled output with all "WRITE(*" and PRINT states first, followed by the WRITEs to unit 6 ... sometimes with the unit -1 output overwriting the initial ones for unit 6.
I fussed with all the various OPEN specifiers with no better results.
Is there an obvious way to direct the outputs to a single file in the order of execution? The DLL is being called from a Java app via C, so a simple redirection may not be available. And the number of WRITE/PRINT statements makes for more editing work than I'd like, if there's an easier way.
Thanks for any suggestions or pointers to references on this topic.
- Longden
Kevin_D_Intel
With IVF 11.1, try the option: /assume:noold_unit_star
Paul_Curtis
Valued Contributor I
Add FLUSH statements following each WRITE to ensure that the output buffer is immediately written to the file. There may be a compiler option to specify FLUSH behavior (easier than going over your code), but I can't find it.
longden_loo
Quoting - Paul Curtis
Yeah I was hoping for some kind of auto-flush option vs manually editing 2000+ WRITE/PRINT lines.
jimdempseyatthecove
On the OPEN statement try adding BUFFERED='NO'
Jim Dempsey
Don't try to open unit -1. Do compile with /assume:noold_def_unit_56. (I think this is the default in 11.1 but I'm away from my references to check.) This should cause both PRINT and WRITE (6) to be merged to unit 6.
longden_loo
Jim Dempsey
Should've mentioned I tried that already with no effect on the order. Thx.
longden_loo
I get compile errors:
ifort command line error: Unrecognized keyword 'noold_def_unit_56' for option '/assume'
... also we noted some time ago that when we switched from IVF-9 to IVF-10, a compile option changed from:
/switch:fe_defunit_56 [ in IVF-9 ]
to
/switch:_disabled_fe_defunit_56 [ in IVF-10 ]
Looking at the IVF-11 projects that were converted from IVF-10, I see that the latter option is still set and since it vague resembles what you're suggesting, I'm wondering if this setting is relevant to my issues as well.
I can't find information on any of these (ie, "_disabled_fe_defunit_56") in the Help screens searches so I'm pretty clueless about what they're trying to do.
Kevin_D_Intel
longden_loo
That did the trick, thx!
Now my "Command Line" enry for Fortran projects show:
/switch:_disabled_fe_defunit_56 /assume:noold_unit_star
... am I correct in leaving in the "/switch" setting? (and what does it mean?)
Kevin_D_Intel
No, remove it. Both /switch forms are old internalspellings from earlier releases.
