29411 Discussions
13.0 compiler bug/RTE: sourced-allocation fails to allocate pointer in certain cases
Neil_Carlson
In a certain circumstance, the execution of a sourced allocation statement does not allocate the pointer (and there is no allocation error); it's as if the statment was just skipped.  It's pretty clear that the 13.0 compiler has generated some bad object code.  This error appears to be triggered when the pointer is a derived type with an allocatable CLASS(*) component, and the pointer is the result variable of the enclosing function.  I've attached a short example code that demonstrates the bug.
Anonymous66
Valued Contributor I
Hello Neil, I have escalated this issue to the developers. The issue number is DPD200237219. I will post any updates I receive to this thread. Regards, Annalee Intel Developer Support
Anonymous66
Hello Neil,
A fix has been found for this issue. We are planning to include it in an update which is currently scheduled for late March.
Annalee
Anonymous66
Hello Neil,
This is issue has been fixed in Intel® Fortran Composer XE for Linux* 2013 Update 3 which is now available at the Intel® Registration Center.
Annalee
