29341 Discussions
1603 error returned for parallel_studio_xe_2016_update5_composer_edition_for_fortran_setup
Tam
I ran into a dead end trying to install this software.
My current OS is win 7 professional and installed windows 8.1 sdk. 2012 x86 redistributable is installed.
When I run the installation, I receive this error code
Execution of installation profess failed
Module name: rtools_setup_64x.exe
Application returned error code 1603
Any help would be appreciated.
joerg_kuthe
According to
https://www.sync.com/help/installation-error-1603/
this is an security issue. This link also claims to provide help.
Steve_Lionel
Another suggestion I have is to select a custom install and deselect the Remote Debugger. This was used for debugging code running on Xeon Phi coprocessors, something Intel no longer offers (and almost nobody used on Windows.)
Tam
So I tried all the suggested things. They haven't worked. Thanks for the attempt though. I tried running the module that returned the 1603 error by itself to see the specific issue with the file.
The rtools_setup_64x.exe returned a error that said 'Error 25541. Failed to open xml C:\Windows\Microsoft.NET\v2.0.50727\Config\machine.config
System error -2147024786
Would posting the installation log help?
joerg_kuthe
Have you checked if
exists?
If not, maybe the following helps:
https://social.technet.microsoft.com/Forums/en-US/86787c69-5909-4885-843e-b8b977e5cc33/error-25541-failed-to-open-xml-file?forum=officesetupdeployprevious
Otherwise you may want to contact Intel's Online Service Center at:
https://supporttickets.intel.com/servicecenter?lang=en-US
To sign in you can use the same credentials as for your download account.
They might be interested in your .log file.
JohnNichols
Valued Contributor III
After 10 years, support for Windows 7 ended on January 14, 2020. We know change can be difficult, so we are here to help you with recommendations for what to do next and to answer questions about end of support.
It is really quite simple to update to Windows 10 and this might solve a lot of problems
Steve_Lionel
And also use a more recent version of the product, if you can.
