29405 Discussions
#6375: Because of COMMON, the alignment of object is inconsistent with its type
Gabriele_B_
I saw this topic for the visual Fortran compiler for Windows, I get the same warning on OSX for a code that I didn't write.
https://software.intel.com/en-us/forums/intel-visual-fortran-compiler-for-windows/topic/296523
What does it mean? what are the "potential performance impact"?
GB
TimP
For example, you might have an odd number of 32 bit data followed by 64 bit data.  That could result in a data access requiring references to 2 cache lines and the hardware piecing the 2 together or splitting them, which may be slow even though you probably have a hardware platform which supports it.
Gabriele_B_
Thanks Tim,
So the only risk is that my code slows down, am I right? My results shouldn't be affected.
TimP
Yes, it's ok, as long as you don't set a nonstandard padding option and use it inconsistently.
jayb
Isn't there a preferred practice, when using COMMON, to list variables largest first, e.g., 64-bit, then in decreasing order of size?  Of course, you need to change all references to the common block.
j
Gabriele_B_
I didn't know about it.
Gabriele_B_
Jayb is your question an answer?or are you wondering about it like me?
