29487 Discussions
64 bit debugging not working - revisited
j0e
This is mostly an FYI on a follow up to the locked post: https://software.intel.com/en-us/forums/topic/515943
I had the same x64 debugging problem (watch variables show up with undefined addresses), so I updated to the latest ver of Fortran composer (Intel(R) Visual Fortran Compiler XE 14.0.5.239), which is update 5, but this did not fix the problem (the problem only occurs with VS2013, but not VS2010).
I did download the FEE.dll for the above thread, and this fixed the problem, but I'm a little surprised that it was not in update 5. Perhaps I updated the wrong component?
thanks - joe
It did not get fixed in the 14.0 stream. It is fixed in version 15.
j0e
thanks Steve!  Just a few min. after posting this, I noticed there was also a 2015 version of the compiler, which I have now upgraded to and that fixed the problem as you noted.  There are enough components to the cluster studio that I am sometime uncertain as to what is the "latest" version :)
