User-defined derived-type i/o
Simon_Geard
I'm trying to find a way of using this to serialize some data. The problem I'm having is that the data are already written into a direct-access file but I can't find a way to use the DTIO functionality to interact with this type of file - for the DTIO to work it seems the file has to be opened as sequential,unformatted. Is it possible to use direct access? Is closing the unit inside the read(unformatted) subroutine and reopening as direct,unformatted a safe thing to to?
Simon
Here's my test program (which doesn't work - bug filed.)
module mymod
    type mytype
        integer a,b
    contains
    procedure :: pru
    procedure :: pwu
    generic :: READ(UNFORMATTED) => pru
    generic :: WRITE(UNFORMATTED) => pwu
    end type mytype
    contains
    subroutine pru (dtv,unit,iostat,iomsg)
    class(mytype), intent(INOUT) :: dtv
    integer, intent(IN) :: unit
    integer, intent(OUT) :: iostat
    character(*), intent(INOUT) :: iomsg
    read (unit,iostat=iostat, iomsg=iomsg) dtv%a,dtv%b
    end subroutine pru
    subroutine pwu (dtv,unit,iostat,iomsg)
    class(mytype), intent(IN) :: dtv
    write (unit,iostat=iostat, iomsg=iomsg) dtv%a,dtv%b
    end subroutine pwu
    end module mymod
    program U537051
    use mymod
    implicit none
    type(mytype) :: t
    integer :: ios
    character(100) :: imsg
    open (unit=1,file='file.dat',form='unformatted',access='direct',recl=2)
    t%a = 3
    t%b = 4
    write (1,rec=4,iostat=ios,iomsg=imsg) t
    if (ios == 0) then
        write (*,*) "write succeeded"
    else
        write (*,*) "Write failed with ",trim(imsg)
    end if
    close (1)
    open (unit=1,file='file.dat',form='unformatted',access='direct',recl=2,status='old')
    t = mytype(0,0)
    read (1,rec=4,iostat=ios,iomsg=imsg) t
      if (ios == 0) then
        write (*,*) "read",t%a,t%b, "should be",3,4
    else
        write (*,*) "Read failed with ", trim(imsg)
    end if
    end program U537051
You are mistaken that UDIO is restricted to sequential I/O. However, inside the child routine you do a sequential read or write to the passed in unit. You are NOT allowed to close and reopen the unit inside the child routine.
However, I've done some testing and things aren't quite working right. Let me look into this some more.
Something's definitely wrong - the child procedure isn't even being called in my test case. Escalated as issue DPD200364274.
Simon_Geard
Thanks for this info. I wasn't expecting closing the unit insdie the child routine to be a good idea and have already deleted that bit of code!
All the examples I've seen for UDIO have been for sequential formatted/unformatted access, e.g. https://software.intel.com/en-us/node/511145
If it isn't restricted to sequential access could you give an example of using direct access please.
module mymod
    type mytype
        integer a,b
    contains
    procedure :: pru
    procedure :: pwu
    end type mytype
    contains
    end subroutine pru
    end subroutine pwu
    end module mymod
    program U537051
    use mymod
    implicit none
    type(mytype) :: t
    integer :: ios
    t%a = 3
    t%b = 4
    if (ios == 0) then
    else
    end if
    close (1)
    t = mytype(0,0)
      if (ios == 0) then
    else
    end if
    end program U537051
Simon_Geard
Thanks. I had the same problem with the procedure not being call and just assummed I had made a mistake. I'll look forward to the fix, hopefully in the v15 stream.
It will be fixed in version 16.
