#7002 : error
sahgal__vardaan
I am new to computation. using ubuntu 18.04,    Intel 19.0.4.20190416
 while working on a souce code i am struck on an error which says  #7002 : error in opening the compiled module file. check include paths [mpi]
what i am doing is as follows
 my bash file reads like this :
   source /opt/intel/compilers_and_libraries_2019.4.243/linux/mkl/bin/mklvars.sh intel64 ilp64 mod
     export CC=$(which mpicc)
    export CXX=$(which mpicxx)
    export FC=$(which mpif90)
export LD_LIBRARY_PATH="/opt/intel/lib"
export DYLD_LIBRARY_PATH="/opt/intel/lib"
export MANPATH="/opt/intel/man"
export PATH=/opt/intel/bin:$PATH
the command    cmake ../source
-- The Fortran compiler identification is Intel 19.0.4.20190416
-- Check for working Fortran compiler: /opt/intel/bin/ifort
-- Check for working Fortran compiler: /opt/intel/bin/ifort  -- works
-- Detecting Fortran compiler ABI info
-- Detecting Fortran compiler ABI info - done
-- Checking whether /opt/intel/bin/ifort supports Fortran 90
-- Checking whether /opt/intel/bin/ifort supports Fortran 90 -- yes
-- Could NOT find OpenMP_Fortran (missing: OpenMP_Fortran_FLAGS OpenMP_Fortran_LIB_NAMES)
-- Could NOT find OpenMP (missing: OpenMP_Fortran_FOUND)
furhter when i type make , it says
Scanning dependencies of target modules
[  1%] Building Fortran object modules/CMakeFiles/modules.dir/precisn.f90.o
[  3%] Building Fortran object modules/CMakeFiles/modules.dir/global_data.f90.o
[  4%] Building Fortran object modules/CMakeFiles/modules.dir/rmt_assert.f90.o
/home/anand/Desktop/test_RMT_CODE/rmt/source/modules/rmt_assert.f90(24): error #7002: Error in opening the compiled module file.  Check INCLUDE paths.   [MPI]
    USE MPI, ONLY: MPI_COMM_WORLD, MPI_ABORT
/home/anand/Desktop/test_RMT_CODE/rmt/source/modules/rmt_assert.f90(24): error #6580: Name in only-list does not exist or is not accessible.   [MPI_COMM_WORLD]
/home/anand/Desktop/test_RMT_CODE/rmt/source/modules/rmt_assert.f90(24): error #6580: Name in only-list does not exist or is not accessible.   [MPI_ABORT]
/home/anand/Desktop/test_RMT_CODE/rmt/source/modules/rmt_assert.f90(45): error #6406: Conflicting attributes or multiple declaration of name.   [MPI_ABORT]
            CALL MPI_ABORT(MPI_COMM_WORLD, errorcode, err)
/home/anand/Desktop/test_RMT_CODE/rmt/source/modules/rmt_assert.f90(37): remark #7712: This variable has not been used.   [ERR]
        INTEGER            :: err
compilation aborted for /home/anand/Desktop/test_RMT_CODE/rmt/source/modules/rmt_assert.f90 (code 1)
modules/CMakeFiles/modules.dir/build.make:1046: recipe for target 'modules/CMakeFiles/modules.dir/rmt_assert.f90.o' failed
make[3]: *** [modules/CMakeFiles/modules.dir/rmt_assert.f90.o] Error 1
modules/CMakeFiles/modules.dir/build.make:1062: recipe for target 'modules/CMakeFiles/modules.dir/rmt_assert.f90.o.provides' failed
make[2]: *** [modules/CMakeFiles/modules.dir/rmt_assert.f90.o.provides] Error 2
CMakeFiles/Makefile2:85: recipe for target 'modules/CMakeFiles/modules.dir/all' failed
make[1]: *** [modules/CMakeFiles/modules.dir/all] Error 2
Makefile:83: recipe for target 'all' failed
make: *** [all] Error 2
Pl suggest what should i do. i feel the issue is related to non linkimng of MPI libs.
a deatiled reply will be highly appreciated.
regards
Steve_Lionel
Linux is not my strong point, but I'm fairly sure that mklvars.sh is not the right script to source, or at least you should source ifortvars.sh first. You somehow also need to make available the MPI modules, which is the fundamental problem here. Do you have the Cluster Edition of Intel Parallel Studio XE installed, to get Intel MPI, or are you using a different MPI? You would need to get the ifort-compiled MPI module in the INCLUDE path for the compiler.
sahgal__vardaan
thank you sir. I also feel what u are saying. I am using intel parallel xe sudio cluster edn 2019
problem is I don't know how to give path suggested by you "You would need to get the ifort-compiled MPI module in the INCLUDE path for the compiler"
can you please assist in giving template ....so that i can include in bash file
regards
Steve_Lionel
I can't - someone else who uses Intel MPI on Linux would need to help you. Or you can ask in https://software.intel.com/en-us/forums/intel-clusters-and-hpc-technology
Barbara_P_Intel
With Intel MPI use mpiicc and mpiifort and mpiicpc to use the Intel compilers.
sahgal__vardaan
hi
I have resolved the above issue but now i am now getting a new error
"A required library with BLAS API not found".  Please specify library
  location.
CMake Error at /usr/share/cmake-3.10/Modules/FindBLAS.cmake:699 (message):
  A required library with BLAS API not found.  Please specify library
  location.
how to find out the path/ location of this file. I am using INtel studio xe cluster 2019 ed.
the CMakeLists.txt is attached
2  how to give the above  path in command in bash file ?
thanks for support
regards
Steve_Lionel
This error is coming from the cmake script, and it uses a "find_package" function that is not shown. We have no idea what it is looking for.
BLAS is provided by the Intel Math Kernel Library, which is installed by default along with Intel Fortran.
