29253 討論
A bug of ifort (IFORT) 2021.7.1 20221019
Zaikun
新貢獻者 I
2,114 檢視
(Update: There is an informative discussion on Fortran Discourse about this bug)
Consider the following code.
! test.f90
program test
implicit none
! Why these strange numbers? Because they come from a real project.
real, parameter :: A(25) = &
    & [1.2409463E+22, 2.8192031E+20, -4.4971432E+21, 1.1558917E+22, -4.7725394E+21, &
    & 2.8192031E+20, 2.8192031E+20, -3.2276437E+21, -3.3936284E+21, 4.1412172E+21, &
    & -4.4971432E+21, -3.2276437E+21, -7.6997325E+20, -4.1627641E+21, -3.4729614E+20,&
    & 1.1558917E+22, -3.3936284E+21, -4.1627641E+21, 2.5757004E+21, -2.4898961E+21, &
    & -4.7725394E+21, 4.1412172E+21, -3.4729614E+20, -2.4898961E+21, 3.5042103E+21]
real :: S(5, 5)
S = reshape(A, [5, 5])
! Is S symmetric?
write (*, *) all(abs(S - transpose(S)) <= 0)
! The numbers in S are horrible. Let's scale it.
S = S / maxval(abs(S))
write (*, *) S
! Is S symmetric?
end program test
Here is what happens on my computer.
$ uname -a && ifort --version
Linux 5.15.0-53-generic #59-Ubuntu SMP Mon Oct 17 18:53:30 UTC 2022 x86_64 x86_64 x86_64 GNU/Linux
Copyright (C) 1985-2022 Intel Corporation.  All rights reserved.
$ ifort test.f90 && ./a.out
T
  0.9999999      2.2718171E-02 -0.3623963      0.9314599     -0.3845887
  2.2718171E-02  2.2718171E-02 -0.2600954     -0.2734710      0.3337145
 -0.3623963     -0.2600954     -6.2047265E-02 -0.3354508     -2.7986396E-02
  0.9314599     -0.2734710     -0.3354508      0.2075594     -0.2006450
 -0.3845887      0.3337145     -2.7986394E-02 -0.2006450      0.2823821
 F
Note that S(3,5) /= S(5,3) after the scaling. This happens when ifort is invoked with -O, -O2, -O3, -O4, or -O5, but not -g, -O0, -O1, or -Ofast.
Is this expected? It seems like a bug to me.
0 積分
1 解決方案
Ron_Green
主席
1,921 檢視
Posted this to Fortran Discourse https://fortran-lang.discourse.group/t/strange-behavior-of-ifort/4846/47
I have some insight into this issue. The mathematics is actually reproducible. The insight came from changing the data in the 5x5, and simplifying the scaling to a simple division. Then using -qopt-report=5 and -S and examining the data in both hex and default float format
Here is my modified test
program test
implicit none
integer :: row , col
  & [-3.4729614E+20, -3.4729614E+20, -3.4729614E+20, -3.4729614E+20, -3.4729614E+20, &
  & -3.4729614E+20, -3.4729614E+20, -3.4729614E+20, -3.4729614E+20, -3.4729614E+20, &
  & -3.4729614E+20, -3.4729614E+20, -3.4729614E+20, -3.4729614E+20, -3.4729614E+20,&
  & -3.4729614E+20, -3.4729614E+20, -3.4729614E+20, -3.4729614E+20, -3.4729614E+20]
real :: S(5, 5)
!S = S / maxval(abs(S))
do col=1,5
 do row=1,5
  S(row,col) = S(row,col) / 1.2409463E+22
 end do
end do
write (*,*) "S after"
do row=1,5
 write(*,'(5(Z8,3x))') S(row,:)
end do
print *, ""
write (*, *) S
! Is S symmetric?
write (*, *)'Is S symmetric?', all(abs(S - transpose(S)) <= 0)
end program test
Now just run a simple compilation
]$ ifort test3.f90
$ ./a.out
 S after
BCE543B9  BCE543B9  BCE543B9  BCE543B9  BCE543B9
BCE543BA  BCE543BA  BCE543BA  BCE543BA  BCE543BA
 -2.7986394E-02 -2.7986394E-02 -2.7986394E-02 -2.7986394E-02 -2.7986396E-02
 Is S symmetric? F
Do you see the pattern? It is stochastic. Not random.
Now, with inside knowledge I know that default, no -O option, gives us -O2 which vectorizes with SSE2, 128 bit registers. You can also verify this by using -dryrun:
$ ifort test3.f90 -dryrun |& grep -i sse
  -D__SSE__ \
  -D__SSE_MATH__ \
  -D__SSE2__ \
  -D__SSE2_MATH__ \
Here we are telling the backend it MAY use SSE2. Not demanding, but suggesting to the backend. You'll see the same define in the -prec-div case - but remember, it's a suggestion not a directive. It may use SSE2, that is all the define is doing. the backend will see -prec-div and decide how to process the loop nest.
 How many 32bit data items in the XMM registers? 4.  Go down the row, in memory order - see the pattern? at optimization, we're packing 4 elements into an XMM register and doing vectorized math. For the 5th element in each row we have a remainder that is not done in a packed vector register with vector instructions. Repeat this for each column. You can see this in the OPT REPORT.
Here's our loop of interest:
   19 !S = S / maxval(abs(S))
   20 do col=1,5
   21  do row=1,5
   22  S(row,col) = S(row,col) / 1.2409463E+22
   23  end do
   24 end do
and the opt-report on that loop
LOOP BEGIN at test3.f90(20,1)
  remark #15542: loop was not vectorized: inner loop was already vectorized
  LOOP BEGIN at test3.f90(21,3)
   remark #15389: vectorization support: reference s(row,col) has unaligned access  [ test3.f90(22,4) ]
   remark #15381: vectorization support: unaligned access used inside loop body
   remark #15305: vectorization support: vector length 4
   remark #15309: vectorization support: normalized vectorization overhead 0.158
   remark #15300: LOOP WAS VECTORIZED
   remark #15450: unmasked unaligned unit stride loads: 1
   remark #15451: unmasked unaligned unit stride stores: 1
   remark #15475: --- begin vector cost summary ---
   remark #15476: scalar cost: 30
   remark #15477: vector cost: 9.500
   remark #15478: estimated potential speedup: 2.020
   remark #15486: divides: 1
   remark #15488: --- end vector cost summary ---
   remark #25015: Estimate of max trip count of loop=1
  LOOP END
  <Remainder loop for vectorization>
   remark #25436: completely unrolled by 1
  LOOP END
LOOP END
Reading this, lots of good stuff. It's vectorizing the inner loop, the 5 elements in a column. But of course the XMM registers process 128 bits or 4 elements. So there is a leftover, which is done in differently that the other 4. Note also that we didn't use -align array32byte and tag the loop as aligned, which might help efficiency here. but that is just an additional optimization we could do manually, not necessary for this discussion.
In the original example, element (3,5) is in a vector mode. Element (5,3) is a remainder, not in a vector mode. Examining the assembly with both cases with and without -prec-div you can see the vector mode, specifically this:
<     rcpps   %xmm2, %xmm0                 #22.4
which is a reciprocal vector instruction of lesser precision. This is done for the first 4 elements. The remainder is done with a div.
<     divss   %xmm1, %xmm3                 #22.4
whereas the code with -prec-div uses div everywhere
>     divps   %xmm1, %xmm2                 #22.4
So - predictable, reproducible results.
Turning on prec-div OR you can also use -no-vec, same effect.
在原始文章中檢視解決方案
8 回應
FortranFan
榮譽貢獻者 III
2,057 檢視
Dear Intel Team members,
Here is a comment re: -fp:fast compiler option with IFORT versus other options at the Fortran DIscourse site that may be of interest here.
FortranFan
榮譽貢獻者 III
2,055 檢視
Intel Forum Admin: is this thread better suited for the Fortran forum since it appears a matter with IFORT product in HPC toolkit?  If so, can you please move it to
https://community.intel.com/t5/Intel-Fortran-Compiler/bd-p/fortran-compiler
Ron_Green
主席
1,988 檢視
I'm reading the discussion on Fortran Discourse.   I will investigate.
ron
Ron_Green
主席
1,973 檢視
This is an interesting little example for many reasons. Where to begin. Let's start with some simple things
1. Intel compilers when invoked without an explicit -O option defaults to O2. And Intel's O2 is aggressive.
2. Optimizations on most compilers come at the expense of precision. You have to balance your needs for highest FP precision and performance.
3. Division, amongst other mathematical expressions and intrinsics, may be done differently depending on optimization level.
4. Every compiler does optimization differently. Does not mean one is 'right' and the other 'wrong'. Just different choices in balancing precision and speed.
Skip to the solution: For IFORT use
-prec-div
option to force precise divisions even under optimzation. Read up on this option [HERE](https://www.intel.com/content/www/us/en/develop/documentation/fortran-compiler-oneapi-dev-guide-and-reference/top/compiler-reference/compiler-options/floating-point-options/prec-div-qprec-div.html). -fp-model is a macro option that sets a number of different FP behaviors. PRECISE triggers -prec-div amongst other behaviors.
You can read on if you want more details.
I'll start with #4. As noted, IFX and IFORT behave differently with this example. Our LLVM-based IFX optimization is radically different than that employed with our legacy proprietary IFORT compiler. You SHOULD expect possible FP differences between these 2 compilers under optimizations. Note in the documentation on -prec-div that this is only an option for IFORT. Why? LLVM FP behavior is different than on our Classic proprietary compiler.
On point #1 above: When you encounter questions about 'what is the compiler doing?' there are easier ways than dumping assembly and reading that. First, use
-dryrun
option. This will show you all internal defines and options passed to the compiler. It's quite helpful.
Next, with IFORT use the
-qopt-report=5
option and examine the .optrpt output.
On Point # 3: Now doing this, and comparing the differences between -prec-div and not at O2 you can see the "Code gen" or code generator is different - difference in number of temporary values ("Locals"). This was a clear indicator that strategy used by the code generator for the division is quite different. Again, read the -O2 and -prec-div options in the [Developer Guide](https://www.intel.com/content/www/us/en/develop/documentation/fortran-compiler-oneapi-dev-guide-and-reference/top/compiler-reference/compiler-options/alphabetical-option-list.html
On point #1, O2 default. Intel prioritizes performance by default "out of box", favoring that over numerical precision when you do not bother to add additional compiler options (if you don't give the compiler any -O options). This philosophy can and has been argued in the community. Some ASSUME that without -O that you would get O0. IFORT has been around for a lot of years and is widely adopted. Where possible, we try to make IFX "out of the box" as close to behavior of IFORT as possible. So no surprises for existing customers, O2 is default. But if you are coming from FLang or gfortran then this default of O2 may be a surprise to you.
Thanks for showing us this example. It was quite interesting.
ron
#IAmIntel
jimdempseyatthecove
榮譽貢獻者 III
1,933 檢視
Does this imply ifx uses the equivalent precision as ifort with -prec-div? .OR. not?
If not, is there a similar functioning option for ifx as -prec-div for ifort?
Jim Dempsey
Ron_Green
主席
1,922 檢視
program test
implicit none
real :: S(5, 5)
do col=1,5
 do row=1,5
 end do
end do
do row=1,5
end do
print *, ""
write (*, *) S
! Is S symmetric?
end program test
]$ ifort test3.f90
$ ./a.out
 S after
 Is S symmetric? F
  -D__SSE__ \
  -D__SSE_MATH__ \
  -D__SSE2__ \
  -D__SSE2_MATH__ \
   20 do col=1,5
   21  do row=1,5
   23  end do
   24 end do
  LOOP END
  LOOP END
LOOP END
Zaikun
新貢獻者 I
1,897 檢視
Thank you very much for this wonderful explanation. Everything makes sense now. So the behavior is a side effect of optimization, not a bug.
andrew_4619
榮譽貢獻者 III
1,877 檢視
The combined FP operation and remainder FP operation was my expectation of what was happening, it is good to see that is confirmed now.  I guess the main point of note is that comparisons of real numbers to zero is not a robust way of coding and can bite back!
回覆
