An afterthought ;
Why not use REAL(16) arithmetic to calculate that?
We are always guaranteed to get the correct answer for ANY combination of inputs,
and the most extreme range (-huge to +huge)
You get a REAL(16) result, which you would round off to get the final number.
NO_STEPS = (real(STOP,16) - real(start,16)+real(step,16))/real(step,16)
Since the compiler supports REAL(16) arithmetic, this should not cause any problems.
Anyway, I wanted to see what the compiler guys think about this, since it completely
avoids the integer overflow curse.
- « Previous
- 1
- 2
- Next »
In Quote #13 I gave a method which DOES NOT USE higher order arithmetic.
It does, however, have an extra divide, and a couple of extra adds.
Basically, it splits the problem into two parts.
You would not need to use it if START and STOP have the same sign, however.
I can't help myself - no offense, but when I read:
"Now of course, those limits have to be really large numbers for that to occur, but who is to say that a given application would NEVER run into that situation?"
I immediately thought of an expression we have in Dutch, somewhat freely translated: If the sky falls, we will all wear a blue hat.
I do not know the English equivalent, but I guess, you can tell the meaning ;).
arjenmarkus wrote:
"If the sky falls, we will all wear a blue hat."
That is so apt! My favorite, very useful when helping someone debug their code, is "De aap komt uit de mouw!", which is even less translatable.
You may like this one too: "Let op het springen van de lintwurm!"
Literally: "Watch the jumping of the tapeworm", used when you are about to confirm something you anticipated to happen. Don't ask me where it comes from :).
Hey, I wear a BROWN hat -
You never know what could be raining down upon you. . . .
Did I "get in dutch" for that?
We ARE SPEAKING Dutch, aren't we?
- « Previous
- 1
- 2
- Next »
