I have created a simple Visula Studio project with a simple call to a Fortran routine. It builds with no errors,but when i run the solution i get the following error.
An unhandled exception of type 'System.BadImageFormatException' occurred in FortranTest1.exe
Additional information: An attempt was made to load a program with an incorrect format. (Exception from HRESULT: 0x8007000B)
C# code
[DllImport("C:\\\\Users\\\\cmural1\\\\Desktop\\\\FortranTestSol\\\\FortranDLL\\\\Debug\\\\FortranDLL.dll", CallingConvention = CallingConvention.Cdecl)]
public static extern void FortranDLL(
[MarshalAs(UnmanagedType.I4)] int int1,
[MarshalAs(UnmanagedType.I4)] int int2,
[MarshalAs(UnmanagedType.I4)] int int3);
private void button1_Click(object sender, EventArgs e)
int int1 = 1, int2 = 2, int3 = 3;
//char[] charVar = { 'a', 'b' };
//Form1.TestFort(ref boolVar, ref intVar, charVar);
Form1.FortranDLL(int1, int2, int3);
Fortran:
SUBROUTINE FortranDLL (int1, int2, int3)
!MS$ATTRIBUTES DLLEXPORT,ALIAS:'FortranDLL' :: FortranDLL
INTEGER :: int1,int2,int3
int2=int1+int3
RETURN
END
please find the attachment of the project.
C# code
Fortran:
int2=int1+int3
RETURN
END
I think you have an argument passing mismatch. The C# code is passing by value (no ref or out keywords before the parameters in the declaration), the Fortran code expects passing by reference (no VALUE attribute). As the Fortran is modifying one of its arguments you probably want to add the ref and out keywords to the C# where appropriate.
I'd strongly recommend a BIND suffix on the Fortran subroutine statement. You can specify the "alias" for the procedure in the NAME clause.
I even build the dll as 64-bit as i am running it on 64-bit machine.
Now i get following error.
An unhandled exception of type 'System.AccessViolationException' occurred in FortranTest1.exe
Additional information: Attempted to read or write protected memory. This is often an indication that other memory is corrupt.
any help would be greatly appreciated.
Please verify that:
a 64-bitapplication loads / uses a 64-bit Fortran DLL
or
a 32-bitapplication loads / uses a 32-bit Fortran DLL
Also, could you attach a test project in a zip-archive instead of arar-archive? I couldn't extract that content.
or
Please take a look at a'Form1.cs' source file and let's assume that a Win32 configuration is selected. Then,
a 64-bit FortranDLL will be imported andloaded at runtimeandit can be the main source of your problems:
[DllImport("C:\\Users\\cmural1\\Desktop\\FortranTestSol\\FortranDLL\\x64\\Debug\\FortranDLL.dll", CallingConvention = CallingConvention.Cdecl)]
In order to avoid any confusions with DLLs compiled for different platforms some suffixes could be added, like:
for a 32-bit platform: FortranDLL32.dll
and
for a 64-bit platform: FortranDLL64.dll
and
I ensured that the solution picks up the correct dll according to the configuration. It gives me the same error again and again. I tried to create new solutions but no use.
Thanks!! I was missing ref keywork before each parameter. I believed MarshallAs doesn't need such declarations.
-Chouhan
-Chouhan
Topic Options
