ABAQUS Verification errors
Cao__Yanmei
Hi all,
I am working on link OneAPI, VS 2019 and ABAQUS.
The verification shows many errors related to user subroutines: 'ifort' is not recognized as an internal or external command'
I searched many solutions,  they edit abaq2017 with different paths, which make me quite confused.
1.
call "C:\Program Files (x86)\Intel\oneAPI\compiler\2022.0.2\env\vars.bat" intel64 vs2019
call "C:\SIMULIA\CAE\2017\win_b64\code\bin\ABQLauncher.exe"
https://info.simuleon.com/blog/free-fortran-compiler-on-windows-for-abaqus-material-modeling-0
2.
SET PATH=%PATH%;C:\Program Files (x86)\Intel\oneAPI\compiler\2021.1.1\windows\bin\intel64;
call "C:\Program Files (x86)\Intel\oneAPI\compiler\2021.1.1\env\vars.bat" -arch intel64
call "C:\Program Files (x86)\Intel\oneAPI\mkl\2021.1.1\env\vars.bat" intel64
https://community.intel.com/t5/Intel-oneAPI-Registration/How-to-link-ABAQUS-with-Intel-One-API-toolkits-to-run-FORTRAN/td-p/1244548
I used both ways and failed. Any suggestion? Many thanks.
Ron_Green
vars.bat will set PATH.  So I think #1 is correct.  but make sure your version is 2022.0.2.  Verify that path to vars.bat is valid on your system.
Cao__Yanmei
Hi Ron,
I double checked path is fine and I used the first one, unfortunately ABAQUS verification still has the same errors with user subroutines. The VS version is of course modified.
mecej4
Open a OneAPI Fortran command prompt (32-bit or 64-bit, to match your Abaqus). Run the Abaqus batch file from that command prompt, instead of any other command prompt, Windows explorer or another shortcut.
Cao__Yanmei
I tried this, firstly, the VS 2019 seems to be set properly.  And it cannot run abaq2017 in the OneAPI command prompt...
SMubasshar
Hi, did you fix the ifort command not found issue? Because i am also facing the same error.
Steve_Lionel
Different problem even if the symptom is the same. See my reply to your other thread.
