If I use an optional dummy as the SOURCE expression in an allocate statement I get some runtime grief.
MODULE ma IMPLICIT NONE TYPE :: ta END TYPE ta CONTAINS SUBROUTINE proc(arg) TYPE(ta), INTENT(IN), OPTIONAL :: arg TYPE(ta), ALLOCATABLE :: x IF (PRESENT(arg)) THEN ALLOCATE(x, SOURCE=arg) END IF END SUBROUTINE proc END MODULE ma PROGRAM p USE ma IMPLICIT NONE TYPE(ta) :: y CALL proc(y) END PROGRAM p
>ifort /check:all /warn:all /standard-semantics "2016-07-20 optional-nonpolymorphic.f90" && "2016-07-20 optional-nonpolymorphic.exe" Intel(R) Visual Fortran Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 16.0.3.207 Build 20160415 Copyright (C) 1985-2016 Intel Corporation. All rights reserved. Microsoft (R) Incremental Linker Version 14.00.24210.0 Copyright (C) Microsoft Corporation. All rights reserved. "-out:2016-07-20 optional-nonpolymorphic.exe" -subsystem:console "2016-07-20 optional-nonpolymorphic.obj" forrtl: severe (157): Program Exception - access violation Image PC Routine Line Source 2016-07-20 option 00007FF7C79E1159 Unknown Unknown Unknown 2016-07-20 option 00007FF7C79E1203 Unknown Unknown Unknown 2016-07-20 option 00007FF7C7A0D8AE Unknown Unknown Unknown 2016-07-20 option 00007FF7C7A0E199 Unknown Unknown Unknown KERNEL32.DLL 00007FFE283B8102 Unknown Unknown Unknown ntdll.dll 00007FFE28C2C5B4 Unknown Unknown Unknown
A variant, with a polymorphic argument fed by a structure constructor, causes a spurious runtime error with the current beta.
MODULE ma IMPLICIT NONE TYPE :: ta END TYPE ta CONTAINS SUBROUTINE proc(arg) CLASS(ta), INTENT(IN), OPTIONAL :: arg CLASS(ta), ALLOCATABLE :: x IF (PRESENT(arg)) THEN ALLOCATE(x, SOURCE=arg) END IF END SUBROUTINE proc END MODULE ma MODULE mb USE ma IMPLICIT NONE TYPE, EXTENDS(ta) :: tb END TYPE tb END MODULE mb PROGRAM p USE ma USE mb IMPLICIT NONE CALL proc(tb()) END PROGRAM p
>ifort /check:all /warn:all /standard-semantics "2016-07-20 optional-polymorphic.f90" && "2016-07-20 optional-polymorphic.exe" Intel(R) Visual Fortran Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 17.0 Beta Build 20160517 Copyright (C) 1985-2016 Intel Corporation. All rights reserved. ifort: NOTE: The Beta evaluation period for this product ends on 7-oct-2016 UTC. Microsoft (R) Incremental Linker Version 14.00.24210.0 Copyright (C) Microsoft Corporation. All rights reserved. "-out:2016-07-20 optional-polymorphic.exe" -subsystem:console "2016-07-20 optional-polymorphic.obj" forrtl: severe (190): for allocate(source=), source needs to be allocated Image PC Routine Line Source 2016-07-20 option 00007FF72F7D26D0 Unknown Unknown Unknown 2016-07-20 option 00007FF72F7D1169 Unknown Unknown Unknown 2016-07-20 option 00007FF72F7D139C Unknown Unknown Unknown 2016-07-20 option 00007FF72F80044E Unknown Unknown Unknown 2016-07-20 option 00007FF72F800D79 Unknown Unknown Unknown KERNEL32.DLL 00007FFE283B8102 Unknown Unknown Unknown ntdll.dll 00007FFE28C2C5B4 Unknown Unknown Unknown
I don't think the OPTIONAL is part of this. The compiler is trying to copy data from the empty type, which it shouldn't. If the type has a component it works. Issue ID is DPD200412834. We have another open issue regarding assignment of empty types which I think is related.
