29273 Discussions
ALLOCATE returns stat = -1 what is that?
twlaub
I've got a code that allocates a small array but the status return from allocate is giving me an error code of -1. Allocate is supposed to return a postive integer in the case of an error. Does anyone know what it means when allocate returns an error of -1?
I haven't seen that and can't spot in the code where that would happen. If you can provide a test case to Intel Premier Support, that would be helpful.
twlaub
Steve,
It turns out that allocate was not returning a status of -1. Somehow our alloc_err variable was getting a value of -1 before hitting an if statement that only called allocate if the array was not already allocated. Since it was, alloc_err was not reset to zero. Thanks for your answer.
