29542 Discussions
Abaqus 2019 and Intel Fortran Compatibility
rodriguez_carrillo__
I am using Abaqus 2019 and I would like to use user material subroutines. The compiler I am using is Intel Composer XE 2011 Update 1.
When I try to use a user material subroutine I get the following error:
ifort: command line error: Unrecognized keyword 'array64byte' for option '/align'
Is this a problem of compatibility between the versions?
In that case, which versions of Intel Fortran are compatible with Abaqus 2019?
Thanks in advance
Steve_Lionel
I don't remember when that option was added, but it was many years ago. You should be able to use the current version with Abaqus. At most you may have to make edits to scripts to have it locate the newer compiler.
Steve_Lionel
