29348 Discussions
Abaqus 6.14 fortran subroutine dllimport not working
Alessandro_N_
Hi all,
I am new to this forum. In the past I was able to call fortran subroutine written by myself from an Abaqus 6.11 user subroutine using the commands cDEC$ attributes dllexport and dllimport. However, now I am trying to do the same thing in Abaqus 6.14 and I get the following error during the linking:
vuamp.obj : error LNK2019: unresolved external symbol <subroutine_name> referenced in function vuamp
It looks like Abaqus is not able to find the .dll.
These are the steps I followed:
1) write my personal subroutine with at the top: cDEC$ attributes dllexport::name
2) create .dll and .obj with command: ifort /dll name.f
3) create .lib with command: lib /out:name.lib name.obj
4) copy .lib file in a folder I point to in the abaqus_v6.env file: add to link_sl the path to the .lib
link_sl=['LINK',
         '/nologo', '/NOENTRY', '/INCREMENTAL:NO', '/subsystem:console', '/machine:AMD64',
         '/NODEFAULTLIB:LIBC.LIB', '/NODEFAULTLIB:LIBCMT.LIB',
         '/DEFAULTLIB:OLDNAMES.LIB', '/DEFAULTLIB:LIBIFCOREMD.LIB', '/DEFAULTLIB:LIBIFPORTMD.LIB', '/DEFAULTLIB:LIBMMD.LIB',
         '/DEFAULTLIB:kernel32.lib', '/DEFAULTLIB:user32.lib', '/DEFAULTLIB:advapi32.lib',
         '/FIXED:NO', '/dll',
         #'/debug', # <-- Debugging
         '/def:%E', '/out:%U', '%F', '%A', '%L', '%B',
         'oldnames.lib', 'user32.lib', 'ws2_32.lib', 'netapi32.lib', 'advapi32.lib',
         'C:\\lib\\6142\\name.lib']
5) Copy .dll file to C:\SIMULIA\Abaqus\6.14-2\code\bin
6) write cDEC$ attributes dllimport::name at the top of the abaqus fortran subroutine file (e.g. vuamp.f)
This same process worked for Abaqus 6.11. The only difference was that the folder where I put the .dll was C:\SIMULIA\Abaqus\6.11-3\exec.
Please let me know if you have any suggestion.
Alessandro
Steve_Lionel
I used the command:
dumpbin -exports prova.lib
which gives me:
Dump of file prova.lib
File Type: LIBRARY
     Exports
       ordinal    name
                  PROVA
One does this from a Fortran command prompt window. By default, Intel Fortran upcases all external names on Windows. On a 32-bit build. it puts an underscore before the name but on a 64-build there is no underscore. The linker is case-sensitive, so if your ABAQUS routine is looking for "prova" it won't match "PROVA". If you can change the name in ABAQUS, that will work. Alternatively, use this in the Fortran code instead of what you have now:
cDEC$ attributes dllexport, alias:"prova" ::prova
I also recommend putting this INSIDE routine prova - it may not be recognized outside it.
The __imp__ means that you have done a DLLIMPORT and this means it wants to link to the import library. For procedures the DLLIMPORT is actually optional (though recommended) - it is required for data you are accessing from a DLL.
Steve_Lionel
Your process is incorrect. Step 2 also creates a .lib - this is what you should be linking to and not a .lib you create from the .obj.
Alessandro_N_
Hi Steve,
thanks for the quick response. Step 2 does not create a .lib file. It creates only the .obj file and the .dll file.
To create the lib file from the .obj I followed the instructions at this link: https://software.intel.com/en-us/node/691875
So I'm afraid that is not the issue.
Alessandro
mecej4
Step 2 did create an import library file. Unfortunately, your unnecessary Step 3 created a static library and, since the name of this library file was the same as that of the import library file, the static library file overwrote the import library file.
You can verify this for yourself by listing the directory contents between each step. Furthermore, Step-1 probably created a .DEF file that is still present there. If so, you can simply use that file to recreate the import library.
Alessandro_N_
Hi mecej4,
Thanks for your response. Step 2 was not creating the .lib file because 'name' in cDEC$ attributes dllexport::name was not the same name of the subroutine. When I use the same name it creates a .lib file and I do not need Step 3.
However, this did not solve the issue. I still get the error: vuamp.obj : error LNK2019: unresolved external symbol <subroutine_name> referenced in function vuamp
Alessandro
Steve_Lionel
Zip the .lib from step 2, along with the build log from the link, and attach it here. (The .lib contains no code - it is just the DLL import linkage.)
Alessandro_N_
Hi Steve,
I attached a zip with .f, .lib, .dll, .exp files.
Where can I find the build log from the link? Is it the error I get when I try to run the Abaqus simulation?
Alessandro
Steve_Lionel
If you're not using Visual Studio to build, then just copy and paste the output you get when you do the build. I want to see the EXACT and COMPLETE text of the error message and, ideally, the link command used.
I can see that prova.lib exports a name called PROVA - spelled exactly like that.
Alessandro_N_
I attached two pictures:
1) The message I get when I build (ifort /dll prova.f)
2) The error message when I try to run the Abaqus simulation with the vuamp subroutine.
mecej4
As of now, we know about at least one inconsistency: the DLL exports "PROVA", whereas Abaqus expects to see "prova". It is easy enough to fix this, but before doing so you should probably find out what exactly the Abaqus ABI requires.
Alessandro_N_
Interesting...
What do you exactly mean when you say the DLL "exports" PROVA? How did you figure this?
You are saying it would be easy enough to fix this. Could you please tell me how?
I do not know how to figure out what the Abaqus ABI requires. Also, what requirements are you referring to specifically?
Thanks for your help!
Alessandro
Alessandro_N_
Also, this is the error I get when I run the Abaqus job (slightly different from what I attached before).
Now it says "unresolved external symbol __imp_prova" even though I am calling the subroutine as "prova". What does "__imp_" mean?
Alessandro
Steve_Lionel
I used the command:
which gives me:
File Type: LIBRARY
     Exports
       ordinal    name
                  PROVA
mecej4
The command dumpbin /exports prova.dll will show the exported name(s).
The _imp prefix is used to signify that the symbol (usually, the decorated name of a routine name) is imported from a DLL.
The compiler has options to control the case of external symbols in the OBJ files that it generates, but I think that you should not try those options yet.
Instead, consult the Abaqus documentation for your specific Abaqus version to find out the external interface specifications. The name decorating and argument passing conventions have to match, and register saving conventions have to be honored.
Alessandro_N_
Steve and mecej4,
I tried with cDEC$ attributes dllexport, alias:"prova" ::prova and it works!
Thanks a lot for your help!
Alessandro
