About ifort real size:
haibuihoang
I am using ifort 9.1.032 on Fedora core 5.
I have a little program that write data to grads file as below:
!------------t.f90
real*4 out (201,161)
open (1, file='t.dat',form='unformatted', access='direct', &
recl=201*161*4)
! Get the data...
write(1,rec=1) out
! Get the data...
write(1,rec=2) out
Now, the t.dat size should be: 201*161*4*2=258888 (B)
When I compile the file t.f90 with pgf90, it's OK. But when I compile with ifort
ifort -w90 t.f90
The result file t.dat's size is 4 times bigger: 1035552 (B)
Of course, it will not be displayed correctly in grads. Please tell me how to fix it!
Many Regards
haibuihoang
Problem solved!
The RECL unit in IFORT is Longword by default (4 byte)
I need to add this to the compiler option:
-assume byterecl
