29284 Discussions
About nafxcw.lib(afxmem.obj) : error LNK2005 ?
lyricx
When I built a full project which contains a Fortran project and a VC
project, in this full project, Fortran calls VC.
But when I built this full project using Visual Studio 2003, it can be
successful, but when I compile this full project, I encountered the following
error:
nafxcw.lib(afxmem.obj) : error LNK2005: "void __cdecl operator delete(void *)" (??3@YAXPAX@Z) already defined in LIBCMT.lib(delete.obj)
Release/GA.exe : fatal error LNK1169: one or more multiply defined symbols found
Someone can help to settle this problem? Thank you very much!
I know I've seen this before, but I can't locate any earlier discussions. My memory says to add nafxcw.lib to the list of "additional dependencies" on the Linker Input property page. The problem has to do with the order in which the MSVC libraries are found.
