This is just probably a silly question, since I already know what solves the problem, but... The issue might be better explained by the following code:
module mod1
type mytype
integer :: a
end type mytype
end module mod1
program Console1
use ifcore
use mod1
implicit none
integer, parameter :: n = 3
character :: key
type(mytype), allocatable :: var1(:,:)
allocate(var1(-1:n+2, -1:n+2))
write(*,*) "the lower bound for var1 is ",lbound(var1, 1)
write(*,*) "the lower bound for var1%a is ",lbound(var1%a, 1)
write(*,*) "the lower bound for var1(:,:)%a is ",lbound(var1(:,:)%a, 1)
key = getcharqq()
end program Console1
Why does the lbound function return the correct lower-bound only when the component "%a" is not present? For the other cases it always returns "1".
module mod1
type mytype
integer :: a
end type mytype
end module mod1
program Console1
use ifcore
use mod1
implicit none
character :: key
key = getcharqq()
Because the Fortran standard says so! You are by no means the first person to be confused by this.
The standard says:
7
Result Value.8 Case (i): If ARRAY is a whole array or array structure component and either ARRAY is an
9 assumed-size array of rank DIM or dimension DIM of ARRAY has nonzero extent,
10 LBOUND (ARRAY, DIM) has a value equal to the lower bound for subscript DIM
11 of ARRAY. Otherwise the result value is 1.
12 Case (ii): LBOUND (ARRAY) has a value whose ith component is equal to LBOUND (AR-
13 RAY, i), for i = 1, 2, ..., n, where n is the rank of ARRAY.
Var1%a is neither a whole array nor an array structure component (it is a structure component of an array) and thus is a "new variable" that has the correct number of elements as in the parent array but does not inherit its lower and upper bounds.
I always thought that the rule only applied to referenced elements (i.e., either pointers or arguments), so it seems I have to re-read the F95 standard before the F03 one gets to be implemented in full.
Thanks for the reply!
