Ankündigungen
Accept Intellisense Suggestions
rwg
Anfänger
3.569Aufrufe
I am using Visual Studio 17.13.6 and Intel Fortran Compiler 2025.0. I activated GitHub Copilot and now I get intellisense suggestions:
But I am not able to accept the suggestion.
Pressing Tab (with or without Shift, Ctrl, Alt) or Enter (with or without Shift, Ctrl, Alt) does not work.
Assigning a key combination does not help (which command should be assigned?).
Has anyone been able to get this to work?
1 Lösung
Andrew_Smith
Geschätzter Beitragender I
3.203Aufrufe
I found this too with f77 style files. But f90 files work well.
Lösung in ursprünglichem Beitrag anzeigen
2 Antworten
Andrew_Smith
3.204Aufrufe
rwg
Anfänger
2.602Aufrufe
That was very helpful. After renaming the file to ending f90 and changing the layout to freeform I can take over the intellisense suggestion by pressing TAB. Thank you very much.
Antworten
