29277 Discussions
Stop VS from converting key words like END to lower case
brianreinhold
Whenever I type in new code in the Visual Studio with the Intel fortran compiler it converts all my keywords to lower case regardless of what I type. I have to do a ctrl-Z at the right time to undo it or retype the word or type an extra letter so it is not a keyword and then delete to get what I want.
Very annoying. How do I make the IDE type what I type?
garraleta_fortran
WHAT VERSION OF VISUAL STUDIO
VS2019 OR VS2022
andrew_4619
I do not see the behaviour that you describe. Maybe it is a setting......
rwg
I've the same problem. I use Visual Studio 2022, 17.13.6 and Intel Fortran Compiler 2025.0.4. Is there a solution (setting or editing intellisense/autocomplete suggestions) for this?
DavidWhite
Valued Contributor II
Same error in VS2019 for me.
