29651 Discussions
Access resource VS_VERSION_INFO from code?
mrvogt
I use VS_VERSION_INFO to stamp my EXE with a version number. Is there a way to access that resource file's version information in code so I can write the used EXE version to the output?
Steve_Lionel
Yes. The Windows API routine GetFIleVersionInfo (declared in Intel Fortran supplied module VERSION) retrieves this information from the EXE or DLL you specify. To get the path to the currently running EXE, use GetModuleFileName (KERNEL32) and pass NULL as the hModule argument.
mrvogt
