Dear All,
A piece of my subroutinelooks like this:
subroutine selecont (ngroup, gtake, kitem, itype)
integer iwork(6), icont(6)
do i=1, ngroup
iwork(i)=i
enddo
do i=1, ngroup
rnd = rand()
==> irnd = int(rnd*(ngroup - i + 1) + 1)
icont(i) = iwork(irnd)
iwork(irnd) = iwork(ngroup - i + 1)
enddo
iwork(i)=i
enddo
do i=1, ngroup
rnd = rand()
enddo
I found that when the main program calls the subroutine the second time,
the line with ==> mark will cause a server error (157), access violation.
I ran the same program unmodified with g77 (under Windows), no problem
appeared.
Does any know how to fix the problem?
Thanks in advance!
S. Doong
There's not enough code here to determine the problem's cause. You can, if you wish, submit a reproducible example to Intel Premier Support and we'll take a look.
Message Edited by sblionel on 04-25-2005 11:33 AM
Using the 'use ifport' statement solves the problem.
tungsh
