29565 Discussions
Access violation error when subroutine is called
Jon_D
New Contributor II
Stripped-down code shown below is generating "access violation" run-time error when ReadAttribute subroutine is called. The error occurs when the program is compiled with IVF 17.0 but not with IVF 16.0. Maybe a bug in the compiler?
Thanks!
MODULE HDF5_CLASS
    IMPLICIT NONE
  TYPE :: HDF5FileType
  CONTAINS
      PROCEDURE,PASS :: New             => New_HDF5File
      PROCEDURE,PASS :: ReadAttribute
      GENERIC        :: ReadData        => ReadAttribute
  END TYPE HDF5FileType
CONTAINS
  SUBROUTINE New_HDF5File(ThisFile,FileName,lInputFile,AccessType,Status)
    CLASS(HDF5FileType)                  :: ThisFile
    CHARACTER(LEN=*),INTENT(IN)          :: FileName
    LOGICAL,INTENT(IN)                   :: lInputFile
    CHARACTER(LEN=*),OPTIONAL,INTENT(IN) :: AccessType
    INTEGER,OPTIONAL,INTENT(OUT)         :: Status
    CHARACTER(LEN=11) :: cAttributesDir
    LOGICAL           :: TrackTime
    cAttributesDir = '/Attributes'
    CALL ThisFile%ReadAttribute(cAttributesDir,'TimeStep%TrackTime',ScalarAttrData=TrackTime)
  END SUBROUTINE New_HDF5File
  SUBROUTINE ReadAttribute(ThisFile,cGrpOrDset,cAttrName,ScalarAttrData,ArrayAttrData)
    CLASS(HDF5FileType),INTENT(IN) :: ThisFile
    CHARACTER(LEN=*),INTENT(IN)    :: cGrpOrDset,cAttrName
    CLASS(*),OPTIONAL,INTENT(OUT)  :: ScalarAttrData,ArrayAttrData(:)
  END SUBROUTINE ReadAttribute
END MODULE HDF5_CLASS
PROGRAM Test
    USE HDF5_CLASS
    IMPLICIT NONE
    TYPE(HDF5FileType) :: ThisFile
    CALL ThisFile%New('SomeFileName',.TRUE.)
END
Kevin_D_Intel
Yes, possibly. I reproduced the fault with our latest 17.0 update 1 but cannot reproduce it with our internal 17.0 development build so there may already be a fix coming. I reported it to Development and will let you know. Thank you for the convenient reproducer.
(Internal tracking id: DPD200416622)
Kevin_D_Intel
Development confirmed this instance is similar to an earlier reported instance (here) and that a fix is expected in our next PSXE 2017 Update 2 tentatively due to release in the next month.
As a work around in the meantime, the error is avoidable by filling all the optional dummy args for the call as shown in the revision to your test case below (see ! work around for added/changed lines).
MODULE HDF5_CLASS
    IMPLICIT NONE
  CONTAINS
CONTAINS
    character(len=8) :: ArrAttrData(2)               ! work around
    ArrAttrData(:) = ['/Attrib0','/Attrib1']         ! work around
    CALL ThisFile%ReadAttribute(cAttributesDir,'TimeStep%TrackTime',ScalarAttrData=TrackTime,ArrayAttrData=ArrAttrData)                                    ! work around
PROGRAM Test
    USE HDF5_CLASS
    IMPLICIT NONE
    integer status                                               ! work around
    status = 0                                                   ! work around
    CALL ThisFile%New('SomeFileName',.TRUE.,'Default',status)    ! work around
    print *,"OK"
END
Mark_H_
I noticed an inconsistent declaration in your code:
22     character(len=7) :: ArrAttrData(2)               ! work around
23
24     cAttributesDir = '/Attributes'
25     ArrAttrData(:) = ['/Attrib0','/Attrib1']         ! work around
You have "len=7" and the data strings are of "len=8". Not sure if this is causing your error though.
Kevin_D_Intel
Thank you. I corrected that above. That was a mistake in the work around code provided and not in the OP's code and not related to the original error.
