29657 Discussions
Access violation writing while copying variable to variable
daninraleigh
I'm getting an access violation while copying value from one variable to another variable. Here is the error message I receive:
Unhandled exception at 0x00494a5a in TEST.exe: 0xC0000005: Access violation writing location 0x004fa7d4.
And here is the code. The error appears while running the following line of code:
[bash]STR(I:I) = ACHAR(IACHAR(STR(I:I)) - DEL)[/bash]
Full subroutine below:
[bash]      SUBROUTINE UPPERCASE(STR)
      IMPLICIT NONE
      CHARACTER(LEN=*), INTENT(IN OUT) :: STR
      INTEGER :: I, DEL
      DEL = IACHAR('a') - IACHAR('A')
      DO I = 1, LEN_TRIM(STR)
         IF (LGE(STR(I:I),'a') .AND. LLE(STR(I:I),'z')) THEN
         END IF
      END DO
      RETURN
      END SUBROUTINE UPPERCASE
[/bash]
Any ideas? Maybe I have a setting incorrect or something else?
Please supply a main program which calls this routine and gets the error.
rasa
When it comes to string conversion there are a ton of code avaialbe in public domain. Just google it. Maybe the following will help you to debug (from a c.l.f. discussion).
[bash]MODULE STRINGS
IMPLICIT NONE
FUNCTION TOUPPER(sString)
CHARACTER(*),INTENT(IN)::     sString
CHARACTER(LEN=LEN(sString)):: TOUPPER
INTEGER::                     i, iAsc
TOUPPER=sString
DO i=1,LEN(sString)
      iAsc=ICHAR(sString(i:i))
      IF (iAsc.GE.97 .AND. iAsc.LE.122) TOUPPER(i:i)=CHAR(iAsc-32)
END DO
END FUNCTION TOUPPER
FUNCTION TOLOWER(sString)
CHARACTER(LEN=LEN(sString)):: TOLOWER
INTEGER::                     i, iAsc
TOLOWER=sString
DO i=1,LEN(sString)
      IF (iAsc.GE.65 .AND. iAsc.LE.90) TOLOWER(i:i)=CHAR(iAsc+32)
END DO
END FUNCTION TOLOWER
END MODULE STRINGS [/bash]
People also use the INDEX function for case conversion. This is independent of the character representation (ASCII, DISPLA. EBCDIC, etc.). It works as:
[bash]elemental function str_toupper ( inpstring ) result( outstring )
implicit none
character(len = 26), parameter:: LOWER_CASE = 'abcdefghijklmnopqrstuvwxyz'
character(len = 26), parameter:: UPPER_CASE = 'ABCDEFGHIJKLMNOPQRSTUVWXYZ'
! -- Argument and result
character(len = *), intent (in) :: inpstring
character(len = LEN(inpstring)) :: outstring
! -- Local variables
integer :: ii, n
! -- Copy input string
outstring = inpstring
! -- Loop over string elements
do ii = 1, LEN(outstring)
  ! -- Find location of letter in lower case constant string
  n = INDEX( LOWER_CASE, outstring( ii:ii ) )
  ! -- If current substring is a lower case letter, make it upper case
  if ( n /= 0 ) outstring( ii:ii ) = UPPER_CASE( n:n )
end do
end function str_toupper[/bash]
Take a look at http://flibs.sourceforge.net/.
HTH.
Lorri_M_Intel
I seeyou are converting in place; are you passing a variable?
Or was it a string-constantsuch as:
CALL UPPERCASE ("Hello!")
By default, string-constants are put into read-onlymemory.
--- Lorri
daninraleigh
Steve,
Yeah, good suggestion. I took the EXE in question and ripped everything out. Left all the settings the same, but ripped everything out to call just that subroutine and it works. So, I need to find out what is offending it. Thanks.
Lorri,
Just an FYI - I'm passing a variable and it works in the stripped down version that way. Thanks for the advice.
--Dan
jimdempseyatthecove
"Access violation writing location" means you wereattempting to write to anaddress that is eitherwrite protected or not mapped to your virtual address (and is not automatically mapped asin first write circumstance). Your code contains a read of the string location STR(I:I)prior to write and youdid not receive "Accessviolation reading location". Therefore it appears that STR(I:) was readable but not writeable. Depending onthe version of Windowsyou canhave virtual memory pages that are marked Execute Only (implies Read Only) as well as Read Only. Pages that you cannot write to might, for example, contain string literals. On your program that exhibits this error, add a WRITE(*,*) STR before your DO loop. See what comes out.
Jim Dempsey
