I would like to know all possibilities to access components of an extended type via a class pointer of a more generalized type. I.E. if i have a type A and a type Aext which extends A, how can I access a component only present in Aext via a class (A) pointer?
So far, the only way I found is a SELECT TYPE construct. While this works, it does addquite alot of code and also seems to be performing very poorly.
Is that the only way to accessspecialized componentsor are there any other possibilities I did not find?
regards,
Thomas
To my knowledge, SELECT TYPE is indeed the only way to access components of an extended type. This is by design. The performance of the construct may to some extent be an implementation issue (for ifort, 11.1 is the first release at all to support SELECT TYPE), but of course it is not recommended to execute the statement in a block enclosed by a loop nest which dominates execution time.
