29413 Discussions
Accessing global variables from a subroutine called from OpenMP task
mcgavinp
Is it legal/valid to access global variables from a subroutine called from an OpenMP task?
ifort 2021.7.0 20220726 doesn't report an error, but appears to produce random results with -check all.  Example:
program test1
  implicit none
  integer :: g, i, j
  g = 42
!$OMP PARALLEL DEFAULT(SHARED)
!$OMP SINGLE
  i = 0
  j = 1
  do while(j<60)
     i = i + 1
!$OMP TASK DEFAULT(SHARED) FIRSTPRIVATE(i,j)
     call sub(i,j)
!$OMP END TASK
     j = j + j
  end do
!$OMP END SINGLE
!$OMP END PARALLEL
  stop
contains
  subroutine sub(i,j)
    implicit none
    integer i,j
!$OMP CRITICAL(unit6)
    write(6,*) i,j,g
!$OMP END CRITICAL(unit6)
  end subroutine sub
end program test1
 Compiled with:  ifort -o test1 test1.f90 -qopenmp -warn all -check all
Expected result:
           5          16          42
           2           2          42
           6          32          42
           1           1          42
           4           8          42
           3           4          42
Obtained result:
           2           2  -858993460
           4           8  -858993460
           6          32  -858993460
           5          16  -858993460
           1           1  -858993460
           3           4  -858993460
 Note: the order lines are output doesn't matter --- just the number in the third column should be 42.
Of course g could be passed to sub() as an argument, but the program I'm assisting with working on has dozens of shared global variables (that don't change in the parallel part) and subroutine calls go several layers deep.
Thanks, Peter McGavin.
Barbara_P_Intel
This is similar to the issue you reported in this thread. Using "-O0" or "-check all" causes the wrong answers. "-check all" disables optimizations.
I added your reproducer to the bug report in that thread.
