Address Error
sunxt
I have encountered some sort "Address Error" when I run my program compiled by ifc V7.1 Build 20030307Z with GNU ld 2.13.90.0.18 20030206 on a RedHat 7 machine.
When I compile with -g option, there is no "Address Error" and the program runs fine. When I copile without -g option, the "Address Error" appears. With -d2 option, I'm able to locate where the diagonostic enters. It was DGEORF of the LAPACK. By the way, I'm also using the Math Kernel Lib from Intel.
I've tried both -O0 and -O2 option. The Address Error occurs in both case.
I'm very puzzled. Also, followed the suggestion on this forum, I'm using old glibc and libthread from RedHat 8.
Thanks for you help!
sunxt
sorry. made a typo in the message. I meant I'm running on a RedHat 9 machine.
Martyn_C_Intel
Can you test this on an RH7 or RH8 system? If this reproduces the problem, please submit it to https://premier.intel.com. Otherwise, it's hard to do much until there is a compiler version which supports RH9.
Martyn
