29273 Discussions
After upgrading, ifort no longer finds include dir for OpenMP
frx
after upgrading to:
$ ifort -V
Intel(R) Fortran Intel(R) 64 Compiler Classic for applications running on Intel(R) 64, Version 2021.12.0 Build 20240211_000000
Copyright (C) 1985-2024 Intel Corporation.  All rights reserved.
ifort: remark #10448: Intel(R) Fortran Compiler Classic (ifort) is now deprecated and will be discontinued late 2024. Intel recommends that customers transition now to using the LLVM-based Intel(R) Fortran Compiler (ifx) for continued Windows* and Linux* support, new language support, new language features, and optimizations. Use '-diag-disable=10448' to disable this message.
I found out that ifort is no longer able to find the include directory for OpenMP.
Let's see a minimal example.
Consider the following source file ('test.f90'):
module test
contains
subroutine do_something
use omp_lib
write(*,*) 'Now: ', omp_get_wtime()
end subroutine do_something
end module test
If I attempt to compile it, I get the following error:
$ ifort -qopenmp -c test.f90
test.f90(7): error #7002: Error in opening the compiled module file.  Check INCLUDE paths.   [OMP_LIB]
use omp_lib
compilation aborted for test.f90 (code 1)
$ ls
test.f90
 On the other hand, if I explicitly add a directory to the include path, ifort compiles the module successfully:
$ ifort -qopenmp -I/opt/intel/oneapi/compiler/2024.1/opt/compiler/include/intel64/ -c test.f90
$ ls
test.f90  test.mod  test.o
Until this last upgrade, there has never been any need to explicitly add this -I option. to tell the compiler where it can find 'omp_lib.mod'.
This looks like a regression.
Mark_Lewy
Valued Contributor I
@Ron_Green It was the OP, @frx,  who was using a custom config file, I just have source /opt/intel/oneapi/setvars.sh in my ~/.bashrc.
From my POV, this isn't a major issue, as we have switched to using IFX for development & production.  I encountered the compilation error with IFORT on a local build of an old branch - easily resolved by building it with our ADO pipeline instead which is using IFORT 2021.11.
Ron_Green
How do you set your environment?
or
source /opt/itnel/oneapi/compiler/2024.1/env/vars.sh
or
do you use Environment Modules or similar env utility?
For the case you show, dump all the defines and paths in your compilation with option -#
ifort -qopenmp -c -# test.f90
frx
Hello Ron, thanks for following up.
I set my environment with:
. /opt/intel/oneapi/setvars.sh --config=~/.config/oneapi.conf
where:
$ cat ~/.config/oneapi.conf
default=exclude
compiler=2024.1
debugger=2024.1
I tried to dump the defines and paths, as you requested:
$ ifort -qopenmp -c -# test.f90 2> define_dump.out
The result is:
/opt/intel/oneapi/compiler/2024.1/bin/../bin/fortcom  \
    -D__INTEL_COMPILER=2021 \
    -D__INTEL_COMPILER_UPDATE=0 \
    -D__unix__ \
    -D__unix \
    -D__linux__ \
    -D__linux \
    -D__gnu_linux__ \
    -Dunix \
    -Dlinux \
    -D__ELF__ \
    -D__x86_64 \
    -D__x86_64__ \
    -D__amd64 \
    -D__amd64__ \
    -D__INTEL_COMPILER_BUILD_DATE=20240211 \
    -D_OPENMP=201611 \
    -D__INTEL_OFFLOAD \
    -D__MMX__ \
    -D__SSE__ \
    -D__SSE_MATH__ \
    -D__SSE2__ \
    -D__SSE2_MATH__ \
    -D__pentium4 \
    -D__pentium4__ \
    -D__tune_pentium4__ \
    -I. \
    -I/opt/intel/oneapi/compiler/2024.1/bin/../opt/compiler/include \
    -I/opt/intel/oneapi/compiler/2024.1/bin/../opt/compiler/include/icc \
    -I/opt/intel/oneapi/compiler/2024.1/bin/../include \
    -I/usr/local/include \
    -I/usr/lib/gcc/x86_64-linux-gnu/6/include \
    -I/usr/lib/gcc/x86_64-linux-gnu/6/include-fixed \
    -I/usr/include/ \
    -I/usr/include \
    -I/usr/include/x86_64-linux-gnu \
    -automatic \
    -omp \
    -omp_simd \
    -O2 \
    "-reentrancy threaded" \
    -simd \
    -offload_host \
    -mGLOB_em64t=TRUE \
    -mP1OPT_version=2021.12.0-intel64 \
    -mGLOB_diag_file=test.diag \
    -mGLOB_long_size_64 \
    -mGLOB_routine_pointer_size_64 \
    -mGLOB_source_language=GLOB_SOURCE_LANGUAGE_F90 \
    -mP2OPT_static_promotion \
    -mGLOB_pack_sort_init_list \
    -mP1OPT_print_version=FALSE \
    -mCG_use_gas_got_workaround=F \
    -mP2OPT_align_option_used=TRUE \
    -mGLOB_gcc_version=630 \
    "-mGLOB_options_string=-qopenmp -c -# " \
    -mGLOB_cxx_limited_range=FALSE \
    -mCG_extend_parms=FALSE \
    -mGLOB_compiler_bin_directory=/opt/intel/oneapi/compiler/2024.1/bin/../bin \
    -mGLOB_as_output_backup_file_name=/tmp/ifortxdWZojas_.s \
    -mIPOPT_activate \
    -mIPOPT_lite \
    -mGLOB_uarch_tuning=0x0 \
    -mGLOB_product_id_code=0x22006d91 \
    -mCG_bnl_movbe=T \
    -mP3OPT_use_mspp_call_convention \
    -mP2OPT_subs_out_of_bound=FALSE \
    -mP2OPT_disam_type_based_disam=2 \
    -mGLOB_ansi_alias \
    -mPGOPTI_value_profile_use=T \
    -mPAROPT_openmp=TRUE \
    -mP2OPT_hpo_omp_simd_only=FALSE \
    -mGLOB_offload_mode=1 \
    -mGLOB_offload_no_openmp=TRUE \
    -mP2OPT_offload_unique_var_string=ifort14721215553pBDSy \
    -mP2OPT_hlo_level=2 \
    -mP2OPT_hlo \
    -mP2OPT_hpo_rtt_control=0 \
    -mIPOPT_args_in_regs=0 \
    -mP2OPT_disam_assume_nonstd_intent_in=FALSE \
    -mGLOB_imf_mapping_library=/opt/intel/oneapi/compiler/2024.1/bin/../bin/libiml_attr.so \
    -mPGOPTI_gen_threadsafe_level=0 \
    -mIPOPT_lto_object_enabled \
    -mIPOPT_lto_object_value=1 \
    -mIPOPT_obj_output_file_name=test.o \
    -mIPOPT_whole_archive_fixup_file_name=/tmp/ifortwarch9qX6Lt \
    -mGLOB_linker_version=2.28 \
    -mGLOB_linker=ld \
    -mGLOB_driver_tempfile_name=/tmp/iforttempfilehkaZX3 \
    -mP3OPT_asm_target=P3OPT_ASM_TARGET_GAS \
    -mGLOB_async_unwind_tables=TRUE \
    -mGLOB_obj_output_file=test.o \
    -mGLOB_source_dialect=GLOB_SOURCE_DIALECT_FORTRAN \
    -mP1OPT_source_file_name=test.f90 \
    -mP1OPT_full_source_file_name=/home/${USER}/INTEL_TEST/test.f90 \
    -mP2OPT_symtab_type_copy=true \
    test.f90
rm /tmp/ifortdashvKyxazo
rm /tmp/ifortdummycrF8HY.c
rm /tmp/ifortsearchdirslt5b38
rm /tmp/ifortxdWZojas_.s
rm /tmp/ifortldashvFsHfAT
rm /tmp/iforttempfilehkaZX3
rm /tmp/ifortargTOAW9D
 If I dump the same output with a previous version of the oneAPI compiler (version 2024.0), the result is very similar, but the important difference seems to be the location where file 'omp_lib.mod' lives:
$ ls -altrF /opt/intel/oneapi/compiler/2024.0/opt/compiler/include/omp_lib.mod
-rw-r--r-- 1 root root 100618 Oct 10  2023 /opt/intel/oneapi/compiler/2024.0/opt/compiler/include/omp_lib.mod
$ ls -altrF /opt/intel/oneapi/compiler/2024.1/opt/compiler/include/intel64/omp_lib.mod
-rw-r--r-- 1 root root 108378 May  8 21:49 /opt/intel/oneapi/compiler/2024.1/opt/compiler/include/intel64/omp_lib.mod
$ ls -altrF /opt/intel/oneapi/compiler/2024.1/opt/compiler/include/omp_lib.mod
ls: cannot access '/opt/intel/oneapi/compiler/2024.1/opt/compiler/include/omp_lib.mod': No such file or directory
It seems to me that the location of file 'omp_lib.mod' has been moved, without changing the implicit include paths...
Or am I completely off-track?
frx
Hi Ron, thanks for following up.
where:
default=exclude
compiler=2024.1
debugger=2024.1
I tried to dump the defines and paths, as you suggested:
The resulting file is:
    -D__unix__ \
    -D__unix \
    -D__linux__ \
    -D__linux \
    -D__gnu_linux__ \
    -Dunix \
    -Dlinux \
    -D__ELF__ \
    -D__x86_64 \
    -D__x86_64__ \
    -D__amd64 \
    -D__amd64__ \
    -D_OPENMP=201611 \
    -D__INTEL_OFFLOAD \
    -D__MMX__ \
    -D__SSE__ \
    -D__SSE_MATH__ \
    -D__SSE2__ \
    -D__SSE2_MATH__ \
    -D__pentium4 \
    -D__pentium4__ \
    -I. \
    -I/usr/include/ \
    -I/usr/include \
    -automatic \
    -omp \
    -omp_simd \
    -O2 \
    -simd \
    -offload_host \
    -mGLOB_em64t=TRUE \
    -mIPOPT_activate \
    -mIPOPT_lite \
    -mCG_bnl_movbe=T \
    -mGLOB_ansi_alias \
    -mP2OPT_hlo \
    -mGLOB_linker=ld \
    test.f90
With an older version of the oneAPI ifort compiler (2024.0) the result is similar, but the difference seems to be the location where file 'omp_lib.mod' lives:
It seems to me that the location of that .mod file was changes, without updating the implicit include paths.
frx
where:
default=exclude
compiler=2024.1
debugger=2024.1
frx
    -D__unix__ \
    -D__unix \
    -D__linux__ \
    -D__linux \
    -D__gnu_linux__ \
    -Dunix \
    -Dlinux \
    -D__ELF__ \
    -D__x86_64 \
    -D__x86_64__ \
    -D__amd64 \
    -D__amd64__ \
    -D_OPENMP=201611 \
    -D__INTEL_OFFLOAD \
    -D__MMX__ \
    -D__SSE__ \
    -D__SSE_MATH__ \
    -D__SSE2__ \
    -D__SSE2_MATH__ \
    -D__pentium4 \
    -D__pentium4__ \
    -I. \
    -I/usr/include/ \
    -I/usr/include \
    -automatic \
    -omp \
    -omp_simd \
    -O2 \
    -simd \
    -offload_host \
    -mGLOB_em64t=TRUE \
    -mIPOPT_activate \
    -mIPOPT_lite \
    -mCG_bnl_movbe=T \
    -mGLOB_ansi_alias \
    -mP2OPT_hlo \
    -mGLOB_linker=ld \
    test.f90
frx
This forum does not allow me to reply as I wish: three previous
attempts to follow up were silently dropped...
Let's try with a shorter answer.
$ grep include define_dump.out
    -I/usr/include/ \
    -I/usr/include \
It seems to me that the location of that .mod file was changed, without updating the implicit include paths.
Mark_Lewy
I also noticed that ifort 2021.12 couldn't open omp_lib on Ubuntu 22.04 LTS (wsl) after upgrading OneAPI HPC with apt.
My .bashrc has "source /opt/intel/oneapi/setvars.sh" in it and the instance has been restarted since the install.
Output from "ifort -qopenmp -c -# omp.f90", where omp.f90 is the same module as test.f90 from the OP:
    -D__unix__ \
    -D__unix \
    -D__linux__ \
    -D__linux \
    -D__gnu_linux__ \
    -Dunix \
    -Dlinux \
    -D__ELF__ \
    -D__x86_64 \
    -D__x86_64__ \
    -D__amd64 \
    -D__amd64__ \
    -D_OPENMP=201611 \
    -D__INTEL_OFFLOAD \
    -D__MMX__ \
    -D__SSE__ \
    -D__SSE_MATH__ \
    -D__SSE2__ \
    -D__SSE2_MATH__ \
    -D__pentium4 \
    -D__pentium4__ \
    -I. \
    -I/opt/intel/oneapi/tbb/2021.12/env/../include \
    -I/opt/intel/oneapi/mpi/2021.12/include \
    -I/opt/intel/oneapi/mkl/2024.1/include \
    -I/opt/intel/oneapi/ippcp/2021.11/include \
    -I/opt/intel/oneapi/ipp/2021.11/include \
    -I/opt/intel/oneapi/dpl/2022.5/include \
    -I/opt/intel/oneapi/dpcpp-ct/2024.1/include \
    -I/opt/intel/oneapi/dnnl/2024.1/include \
    -I/opt/intel/oneapi/dev-utilities/2024.1/include \
    -I/opt/intel/oneapi/dal/2024.2/include/dal \
    -I/opt/intel/oneapi/compiler/2024.1/opt/oclfpga/include \
    -I/opt/intel/oneapi/ccl/2021.12/include \
    -I/usr/lib/gcc/x86_64-linux-gnu/11/include \
    -I/usr/include/ \
    -I/usr/include \
    -automatic \
    -omp \
    -omp_simd \
    -O2 \
    -simd \
    -offload_host \
    -mGLOB_em64t=TRUE \
    -mGLOB_diag_file=omp.diag \
    -mGLOB_gcc_version=1140 \
    -mGLOB_as_output_backup_file_name=/tmp/ifortKoMrMbas_.s \
    -mIPOPT_activate \
    -mIPOPT_lite \
    -mCG_bnl_movbe=T \
    -mGLOB_ansi_alias \
    -mP2OPT_offload_unique_var_string=ifort0286250303y2Gwbl \
    -mP2OPT_hlo \
    -mIPOPT_obj_output_file_name=omp.o \
    -mIPOPT_whole_archive_fixup_file_name=/tmp/ifortwarchja0ese \
    -mGLOB_linker_version=2.38 \
    -mGLOB_linker=ld \
    -mGLOB_driver_tempfile_name=/tmp/iforttempfile8Rf2s5 \
    -mGLOB_obj_output_file=omp.o \
    -mP1OPT_source_file_name=omp.f90 \
    -mP1OPT_full_source_file_name=/home/lewym/intel/src/omp.f90 \
    omp.f90
rm /tmp/ifortdashvZOvmCE
rm /tmp/ifortdummyU6Vx28.c
rm /tmp/ifortsearchdirs5M2S91
rm /tmp/ifortKoMrMbas_.s
rm /tmp/ifortldashvA1shdW
rm /tmp/iforttempfile8Rf2s5
rm /tmp/ifortarglSyL5t
I note that ifx compiles this with no issue:
ifort (IFORT) 2021.12.0 20240211
ifx (IFX) 2024.1.2 20240508
IFORT 2021.11 seems to be working fine.
Mark_Lewy
@Ron_Green I note that in 2024.1 that omp_lib.mod is now in compiler/include/intel64/omp_lib.mod c.f. compiler/include/omp_lib.mod in 2024.0:
lewym@ADSKPW015RGM:~/intel/src$ find /opt/intel/ -name omp_lib.mod
/opt/intel/oneapi/2024.0/opt/compiler/include/omp_lib.mod
/opt/intel/oneapi/2024.1/opt/compiler/include/intel64/omp_lib.mod
And also that for ifx -#, we have this in the output (hence its ability to compile without errors):
<elided>
-I/opt/intel/oneapi/compiler/2024.1/opt/compiler/include/intel64 \
-I/opt/intel/oneapi/compiler/2024.1/opt/compiler/include \
<elided>
As a quick and dirty workaround,  "ifort -I/opt/intel/oneapi/compiler/2024.1/opt/compiler/include/intel64 -qopenmp -c omp.f90", would work.
Ron_Green
@Mark_Lewy   one difference I see in your env is that you use your own oneapi.conf file.  Have you tried to source setvars.sh without the config file?
I am thinking that the exclude everything but the compiler and debugger may be missing the omp and runtime setup.  The OMP RT could be considered a shared resource instead of a compiler resource.  That is probably a bug in setvars.  Setvars is created outside of the compiler teams and I really don't know the logic they use.
As an alternative, if you want only the compilers, try sourcing just the compiler 'vars.sh' file which is in
<oneapi path>/compilers/<version>/env/vars.sh
Each component has it's one "env/" dir with their own component-level vars script.  I suspect a bug in setvars.sh wrt the 'exclude' default
Mark_Lewy
frx
Yes, I am the one who is using a custom config file, but I have also just tried without any config file:
and it does not make any difference. Same error, unless I manually add the include directory with the -I option.
And switching to ifx is not an option for the time being: I am seeing some 30 % performance hit on the generated executable (I mean the same source code, compiled with ifx, runs about 1.30 slower than with ifort). This is really worrying, especially taking into account that Intel is planning to completely drop ifort by the end of 2024...
CoryG
I have had exactly the same issue. I updated the intel compilers yesterday on Ubuntu via apt-get, and my build all of a sudden started failing. The compiler was not able to find omp_lib. I have always just used ```source /opt/intl/oneapi/setvars.sh```. No custom config. Explicitly adding the path to omp_lib fixed the compile issue, but this does seem like a bug.
Ron_Green
@frx what compiler options are you using with ifx?  The optimizer in ifx is completely different than in ifort, so the options should be reexamined.  I would recommend
-O2 -xhost -flto -align array64byte
along with anything else you use.  Are you using fp-model or -fpe0?  Show me your list of options maybe we can get ifx closer to ifort.  We have several performance bugs being fixed in 2024.2 which should be here in about a month.
frx
The application is a numerical solver. The compiler options used with ifort are:
OMPI_FC=ifort mpifort -m64 -ip -fp-model precise -ftz -shared-intel -fpp  -qopenmp -mcmodel=medium -O3 -xAVX -fno-alias -fno-fnalias -assume buffered_io
I have just tried the following options with ifx:
OMPI_FC=ifx mpifort -m64 -fp-model precise -ftz -shared-intel -fpp  -qopenmp -mcmodel=medium -flto -align array64byte -O3 -xAVX -fno-alias -assume buffered_io
This leads to incorrect execution of the solver application (which almost immediately produces NaNs).
Dropping the -flto option:
OMPI_FC=ifx mpifort -m64 -fp-model precise -ftz -shared-intel -fpp  -qopenmp -mcmodel=medium -align array64byte -O3 -xAVX -fno-alias -assume buffered_io
leads to an execution which is about 28 % slower than with ifort. Almost the same computing time as with ifx without the -align array64byte option...
BTW, I use the APT repositories on a Debian system.
frx
ifort from the 2024.2 release:
$ ifort -V
Intel(R) Fortran Intel(R) 64 Compiler Classic for applications running on Intel(R) 64, Version 2021.13.0 Build 20240602_000000
is able to correctly find the include dir for OpenMP, so I think this issue may be considered solved by this new release.
In the meantime, I again performed a simple test on ifx (now from the 2024.2 release). I am still seeing a performance hit on the generated executable, but now it's a roughly 11 % performance hit (I mean the same source code, compiled with ifx, runs about 1.11 slower than with ifort). This is still worrying, taking into account that Intel is planning to completely drop ifort by the end of 2024, but, at least it seems that ifx is somewhat improving from the optimization point of view...
Ron_Green
@Mark_Lewy forgot you wanted the debugger also.  source it's env/vars.sh also
Ron_Green
@CoryG @frx @Mark_Lewy
Perhaps it's the packages from the repositories?  On my hosts I use the IRC offline installer packages, not package managers.  Could you share if you
use a package manager
if so which one?  APT, YUM/DNF, or Zypper?
I'm wondering if this is a bug in the package delivered by our repos.  I don't see the issue with the packages I use from the IRC downloads.
Mark_Lewy
Hi @Ron_Green ,
If you didn't pick this up from my original reply in this thread, I'm using APT on Ubuntu 22.04 LTS (in WSL FWIW).
CoryG
That would make sense. I used APT on Ubuntu 22.
