Allocatable Arrays
chris_hawkins
Is there a method to resize AN EXISTING dynamic array without trashing the existing contents? i.e. similar to "REDIM PRESERVE" in Visual Basic. The only way that I can think of is to copy the contenst into a temporary array of the same dimensions / size, deallocate the original array, allocate it again and then copy the contents of the tempoary array back. Seems somewhat ineligant!
Jugoslav_Dujic
Valued Contributor II
No -- but CVF now supports ALLOCATABLE arguments (which is a feature from Fortran 2000 draft), so you can solve it more elegantly and generally:
SUBROUTINE ReAlloc(A, n)
REAL, ALLOCATABLE:: A(:)
INTEGER::           n, nOld
REAL, ALLOCATABLE:: Temp(:)
nOld = SIZE(Temp)
IF (nOld > n) RETURN
ALLOCATE(Temp(nOld))
Temp=A
DEALLOCATE(A)
ALLOCATE(A(n))
A(1:nOld) = Temp
END SUBROUTINE Realloc
Now you can reallocate any array in a single subroutine call.
Jugoslav
Intel_C_Intel
Shouldn't it be nOld=SIZE(A), not
> nOld = SIZE(Temp)
Eddie
chris_hawkins
Thanks - I arrived at almost the same solution but at least I know that I wasn't missing something. CJH
