Allocatable Scalar Derived Types and Generic Assignment - having trouble setting them up.
FortranFan
Is the following code valid per the latest standard?  The compiler does not give any errors, but the program encounters run-time exception when the allocatable scalar derived type is constructed using an assignment at line 180.  Sourced allocation that makes use of the same assignment - see line 161 - seems to work ok.  I'm trying to figure out whether my problem lies in the finalizer or the assignment routine.
Thanks much,
[fortran]
   MODULE TestMod
      IMPLICIT NONE
      PRIVATE
      !.. Public items
      PUBLIC :: ASSIGNMENT(=)
      PUBLIC :: NewStringClass
      !.. Character Type
      TYPE, PUBLIC :: MyStringClass
         PRIVATE
         CHARACTER(LEN=:), ALLOCATABLE :: m_MyString
      CONTAINS
         PRIVATE
         FINAL :: CleanStringClass
         PROCEDURE, PASS(This) :: Clear => ClearAllocatables
         PROCEDURE, PASS(This) :: Init => InitStringClass
         PROCEDURE, PASS(This), PUBLIC :: GetString
         PROCEDURE, PASS(This), PUBLIC :: SetString
      END TYPE MyStringClass
      INTERFACE ASSIGNMENT(=)
         MODULE PROCEDURE StringClassAssign
      END INTERFACE
   CONTAINS
      !.. Initialize
      PURE ELEMENTAL SUBROUTINE InitStringClass(This)
         !.. Argument list
         CLASS(MyStringClass), INTENT(INOUT) :: This
         CALL This%Clear()
         RETURN
      END SUBROUTINE InitStringClass
      !.. Get the value
      PURE ELEMENTAL FUNCTION GetString(This) RESULT(Value)
         !.. Argument list
         CLASS(MyStringClass), INTENT(IN) :: This
         !.. FUNCTION RESULT
         CHARACTER(LEN=:), ALLOCATABLE    :: Value
         IF (ALLOCATED(This%m_MyString)) THEN
            Value = This%m_MyString
         ELSE
            Value = "ERROR: String not allocated."
         END IF
         RETURN
      END FUNCTION GetString
      !.. Set the value string class
      PURE ELEMENTAL SUBROUTINE SetString(This, Value)
         !.. Argument list
         CHARACTER(LEN=*), INTENT(IN)        :: Value
         IF (LEN(Value) > 0) THEN
            This%m_MyString = Value
         END IF
         RETURN
      END SUBROUTINE SetString
      !.. Finalize Class
      PURE ELEMENTAL SUBROUTINE CleanStringClass(This)
         !.. Argument list
         TYPE(MyStringClass), INTENT(INOUT) :: This
         CALL This%Clear()
         RETURN
      END SUBROUTINE CleanStringClass
      !.. Clear Allocatables
      PURE ELEMENTAL SUBROUTINE ClearAllocatables(This)
         !.. Argument list
         !.. Local variables
         INTEGER :: Istat
            DEALLOCATE(This%m_MyString, STAT=IStat)
            IF (IStat /= 0) THEN
               !.. Insert some error handling here
            END IF
         END IF
         RETURN
      END SUBROUTINE ClearAllocatables
      !.. Assignment
      PURE ELEMENTAL SUBROUTINE StringClassAssign(Lhs, Rhs)
         !.. Argument list
         CLASS(MyStringClass), INTENT(OUT) :: Lhs
         CLASS(MyStringClass), INTENT(IN)  :: Rhs
         CALL Lhs%Init()
         IF (ALLOCATED(Rhs%m_MyString)) THEN
            Lhs%m_MyString = Rhs%m_MyString
         END IF
         RETURN
      END SUBROUTINE StringClassAssign
      !.. Constructor function
      PURE ELEMENTAL FUNCTION NewStringClass() RESULT(NewObj)
         !.. Function result: new class
         TYPE(MyStringClass) :: NewObj
         CALL NewObj%Init()
      END FUNCTION NewStringClass
   END MODULE TestMod
   PROGRAM TestFor
      USE TestMod, ONLY : MyStringClass, NewStringClass, ASSIGNMENT(=)
      IMPLICIT NONE
      TYPE(MyStringClass) :: MyClass1
      TYPE(MyStringClass), ALLOCATABLE :: MyClass2
      INTEGER :: Istat
      WRITE(6,*) " --- Test program --- "
      !.. Try class 1
      CALL MyClass1%Init()
      CALL MyClass1%SetString( "Test" )
      WRITE(6,*) " Class1 String: ", MyClass1%GetString()
      !.. Reset
      MyClass1 = NewStringClass()
      !.. Try class 2, method 1
      ALLOCATE(MyClass2, SOURCE=NewStringClass(), STAT=Istat)  ! <-- This seems to work.
      IF (IStat == 0) THEN
         CALL MyClass2%SetString( "Hello World!" )
         WRITE(6,*) " Class2 String: ", MyClass2%GetString()
      ELSE
         WRITE(6,*) " Class2 Allocation failed.  STAT = ", Istat
         STOP
      END IF
      !.. Clean class 2
      IF (ALLOCATED(MyClass2)) THEN
         DEALLOCATE(MyClass2, STAT=Istat)
         IF (Istat /= 0) THEN
            STOP
         END IF
      END IF
      !.. Try class 2, method 2
      MyClass2 = NewStringClass()                              ! <-- This does NOT work, why??
      STOP
   END PROGRAM TestFor
[/fortran]
[plain]
  Class1 String: Test
  Class1 String: ERROR: String not allocated.
  Class2 String: Hello World!
forrtl: severe (157): Program Exception - access violation
Image              PC                Routine            Line        Source
TestFor64.exe      000000013FBB1395  TESTMOD_mp_CLEARA          90  TestMod.f90
TestFor64.exe      000000013FBB145D  TESTMOD_mp_STRING         116  TestMod.f90
TestFor64.exe      000000013FBB20CC  MAIN__                     44  TestFor.f90
TestFor64.exe      000000013FC06076  Unknown               Unknown  Unknown
TestFor64.exe      000000013FBF03DF  Unknown               Unknown  Unknown
kernel32.dll       00000000774A652D  Unknown               Unknown  Unknown
ntdll.dll          0000000077B9C541  Unknown               Unknown  Unknown
[/plain]
FortranFan
I meant defined assignment, not generic.
IanH
You have defined assignment for your type.  Defined assignment doesn't result in reallocation on assignment of the top level variable.  Effectively StringClassAssign gets called with an unallocated Lhs.
FortranFan
Ian,
I thought as much, so I figured I'll give the following a try.  But it didn't work either.
[fortran]
      !.. Assignment
         !.. Argument list
         CLASS(MyStringClass), INTENT(OUT), ALLOCATABLE :: Lhs
         !.. Local variables
         INTEGER :: Istat
         ALLOCATE(Lhs, SOURCE=Rhs, STAT=Istat)
         END IF
         RETURN
[/fortran]
IanH
Well, that shouldn't compile - it violates F2008 C1289 (thou shall not have allocatable dummy arguments in an elemental procedure).  I have vague recollections of that coming up here before (but then again, all my recollections are vague, and often just plain wrong).
What do you need the defined assignment for?
(If you are going to have defined assignment, best to make it type bound, like your other bindings.)
FortranFan
Oh, I didn't need the elemental attribute - I was only trying things out in a hurry and had that setting from previous code.  However, the compile indeed does not flag any error - if Steve or anyone else at Intel wants to take a look and see if it merits opening an incident.
My eventual goal for this defined assignment is for application in a callable library that will be used by developers who mainly program in other  OO-based languages, not Fortran, and whose first baby steps to instantiate a "class" would have been:
[csharp]
obj = new SomeClass( "{ class constructor parameters}" )
[/csharp]
IanH
Your defined assignment is just doing what intrinsic assignment would do, but with the limitation that the defined assignment either needs to be for an allocatable variable (the thing on the left hand side of the =) or a non-allocatable - it cannot do both.
(This is the same sort of [unfortunate] issue arising as in the IOMSG discussion - you cannot "overload" generic interfaces on the basis of the allocatable attribute alone (in F2008 you can differentiate between allocatable and pointer, but not allocatable and not-allocatable).  I don't see why the language rules, in future, couldn't be changed though.)
Defined assignment here might be useful to do something like take a right hand side character variable and assign it to your MyString type (or vice-versa).  But again, you either support left hand side allocatable or not-allocatable.
Some of your other procedures also simply reproduce what happens automatically if the argument is INTENT(OUT), or deallocated, or whatever.  For example - there's no need for your type, as presented, to have a finalizer.
You might be interested in the possibility of overloading the compiler provided structure constructor.  That lets you do something like:
[fortran]TYPE(MyStringClass) :: s
s = MyStringClass(whatever...)[/fortran]
In the absence of defined assignment for MyStringClass to MyStringClass, that works whether s is allocatable or not.  That should start looking pretty natural for your other OO language friends.
Further examples attached.  If Dr Fortran hasn't fallen asleep while reading this... there's an example of a ICE in here with 14.0.0 and /check:all /warn:all /standard-semantics too (uncomment the #ICE lines).
(Why the "#6931: Fortran 2003 does not allow this assignment statement" warnings if /stand is present?)
Steven_L_Intel1
Three cups of coffee later and I'm awake again. I will look into the issues raised here regarding the ICE and lack of an error when there should be one.
Steven_L_Intel1
Ian, you previously reported the missing error, which is undoubtedly why it sounds familiar - it's being worked on.
Standards warning was also previously reported and is being worked.
ICE escalated as issue DPD200248888.
FortranFan
Thanks much for the explanation and sample code, Ian.  So I'll do away with the idea of "defined assignment" for allocatable types for good and stick with structor constructors as you show [even if the future language standards were to provide more flexibility with allocatable types, I don't expect to find a compiler that supports that aspect during my lifetime :-) ].
Yes, your comments duly noted.  The above example was a version that I stripped down quickly from another, more complicated derived type and I didn't fully get rid of all the extraneous stuff: for this other derived type, it had made sense for us to have "custom" procedures to override some intrinsic aspects as well as a finalizer.
Steven_L_Intel1
fan-string2.f90 now works in the version 16 compiler, as long as standard-semantics is enabled.
