Allocatable array class components
abhimodak
Scalar allocatable class component works but array does not. Debugger does not show components of the extended type.
Perhaps this is a known issue (or am I making some mistake?)....please see the program below.
For input value of iType = 1:
When the class component is an array, I don't get the "real" component printed. The debugger shows the correct extented type picked up by the select case construct; however, the object "tree" in the debugger does not show the real component. The same is true for the scalar (variable Parcel%Object). However, the print-out does show the real component.
Abhi
[fortran]
      Module OM
         Implicit None
         Type newBase
            Integer :: i = -1
         Contains
            Procedure :: Show
         End Type newBase
         Type, extends(newBase) :: newExtension
            Real :: r = 1.0d0
         End Type newExtension
      Contains
         Subroutine Show(OBJ)
            Class(newBase), Intent(IN) :: OBJ
            Select Type(OBJ)
               Type is (newBase)
                  Print *, OBJ%i
               Type is (newExtension)
                  Print *, OBJ%i, OBJ%r
            End Select
         End Subroutine Show
      End Module OM
      Module Shree
         Use OM
         Implicit None
         Type newWrapper
            Class(newBase), Allocatable :: Object(:)
         End Type newWrapper
         Type newCollection
         End Type newCollection
      End Module Shree
      Program Test_ClassInType
         Use Shree
         Implicit None
         Integer :: iType, ial(2)
         Type(newWrapper) :: Package
         Type(newCollection) :: Parcel
         Write(*,*) "Give iType: (0 or 1)"
         Read(*,*) iType
         Select Case(iType)
            Case(0)
               Allocate(newBase :: Package%Object(2), stat=ial(1))
               Allocate(newBase :: Parcel%Object, stat=ial(2))
            Case(1)
               Allocate(newExtension :: Package%Object(2), stat=ial(1))
               Allocate(newExtension :: Parcel%Object, stat=ial(2))
            Case Default
               Write(*,*) "Invalid."
         End Select
         Write(*,"(A,I0)") "ial(1)=", ial(1)
         Write(*,"(A,I0)") "ial(2)=", ial(2)
         Write(*,*)
         Write(*,*) "Showing Package%Object(1)"
         Call Package%Object(1)%Show()
         Write(*,*)
         Write(*,*) "Showing Parcel%Object"
         Call Parcel%Object%Show()
      End Program Test_ClassInType
[/fortran]
Is the issue that the debugger doesn't show the right value, but the program works anyway? Debugger support for polymorphic types has some issues we are working on.
abhimodak
Hi Steve
The problem is with both: (a) program does not work as expected, (b) debugger does not show correct information.
(a) More specifically, for iType == 1, Package%Obejct should be an array of extended type. However, this does not seem to happen. Whereas Parcel%Object is correctly becomes a variable of extended type. The write statement prints only integer component for Package%Object(1) while both, real and integer, components are printed for Parcel%Object.
(b) I am aware of issues related to the debugger; although this one also falls unders same category, I think, it is happening in a "new" place.
Abhi
Ok, thanks. I can reproduce both issues. I have escalated this as DPD200161615.
The program not working was fixed in 12.0 Update 2.
