Allocatable arrays in OpenMP
eos_pengwern
Can anyone suggest why, when this code works perfectly:
do j=1, n
allocate(a(n, 2), b(n, 2), c(n, 2, 1))
do i=1, n
call foo(m, n, parms(i,j), results(i,j), a, b, c)
end do
deallocate(a,b,c)
call PrintResults(results)
end do
...this code fails with a message saying "allocatable array is already allocated":
call OMP_SET_NUM_THREADS(1)
!$OMP PARALLEL DO DEFAULT(SHARED) PRIVATE(i, j, a, b, c)
do j=1, n
do i=1, n
end do
deallocate(a,b,c)
!$OMP CRITICAL
!$OMP END CRITICAL
end do
!$OMP END PARALLEL DO
As far as I know the use of an allocatable array as a private variable is perfectly legal OpenMP so long as the array is both allocated and deallocated within the parallel section, and broadly similar code (wth the same sort of allocate-deallocate structure) works well elsewhere in my application.
Stephen.
pbkenned1
Yes, it's fine to have an allocatable array in an OpenMP PRIVATE clause.
What compiler version are you using?Can you attach an example that reproduces the error?
I can't reproduce "allocatable array is already allocated", whether I use 1 thread or n threads (I'm using a 4 core system).
C:\>type allocable.f90
program F76780
include 'omp_lib.h' !need this for library calls
integer i,j,n,ithr
real, allocatable :: a(:,:), b(:,:), c(:,:,:)
n = 4
! call OMP_SET_NUM_THREADS(1) <<<=== just a comment...
!$OMP PARALLEL DO DEFAULT(SHARED) PRIVATE(i, j, a, b, c, ithr)
do j=1, n
do i=1, n
! call foo(m, n, parms(i,j), results(i,j), a, b, c)
!$OMP CRITICAL
ithr = omp_get_thread_num()
print *,'thread = ',ithr,' j =',j,' i =',i
!$OMP END CRITICAL
end do
deallocate(a,b,c)
end do
end program F76780
C:\>ifort -Qopenmp allocable.f90
Intel Visual Fortran Intel 64 Compiler Professional for applications running on Intel 64, Version 11.1 Build 20100414 Package ID: w_cprof_p_11.1.065
C:\>allocable.exe
thread = 0 j = 1 i = 1
thread = 1 j = 2 i = 1
thread = 2 j = 3 i = 1
thread = 3 j = 4 i = 1
thread = 0 j = 1 i = 2
thread = 1 j = 2 i = 2
thread = 2 j = 3 i = 2
thread = 3 j = 4 i = 2
thread = 0 j = 1 i = 3
thread = 1 j = 2 i = 3
thread = 2 j = 3 i = 3
thread = 3 j = 4 i = 3
thread = 0 j = 1 i = 4
thread = 1 j = 2 i = 4
thread = 2 j = 3 i = 4
thread = 3 j = 4 i = 4
C:\>
jimdempseyatthecove
Steven,
This sounds like an old version problem. If you are unable to update your compiler, then try adding array pointers pa, pb, and pc (same ranks as a, b, c)
!$OMP PARALLEL DO DEFAULT(SHARED) PRIVATE(i, j, pa, pb, pc)
do j=1, n
nullify(pa)
nullify(pb)
nullify(pc)
allocate(pa(n, 2), pb(n, 2), pc(n, 2, 1))
do i=1, n
call foo(m, n, parms(i,j), results(i,j), pa, pb, pc)
end do
deallocate(pa,pb,pc)
!$OMP CRITICAL
!$OMP END CRITICAL
end do
Jim Dempsey
eos_pengwern
Thanks Patrick and Jim; I'm trying to do this with V11.1.051 and my support subscription has expired, but I'm planning to renew and upgrade in the next month or so.
In reality, "foo" has a few extra parameters which in the serial version of the program were pointers. When I first tried to parallelise this section of code, I kept getting "internal compiler errors" until I took the pointers out. In the current form with no pointers it will at least compile, and your feedback (together with similar feedback when I asked this same question in the OpenMP forum) has convinced me that at least my syntax is sane and there's no fatal flaw in my approach. Perhaps I'll accelerate that compiler upgrade.
Stephen.
butette
Are ALLOCATABLE or POINTER arrays declared to be PRIVATE inside a parallel region allocated on the global heap or private stack for each thread as implemented by Intel compiler ?
pbkenned1
All allocatable arrays and pointer arrays are dynamically (heap) allocated, regardless of whether or not OpenMP is being used. If OpenMP is being used, ALLOCATABLE objects in a PRIVATE list are allocated from a heap local to each thread. On the other hand, if they are SHARED dynamic objects (specified in a SHARED list, or just by default), they are allocated from the global heap. Synchronization will be needed to avoid data races.
Patrick Kennedy
Intel Developer Support
butette
Patrick,
So each thread maintains its thread-local heap as part of the global heap ? Is there any penalty/synchronization that I have to worry about when using thread local ALLOCATABLE objects ? Also if this is the case, why can't the compiler put automatic arrays on the heap when they are used inside a parallel region through the use of the -heap-arrays option ?
