Allocatable arrays in modules
Alireza_Forghani
In my code, there is a data container module that includes allocatable arrays.
The main subroutine, calls a subroutine to initialize the arrays. Both main subroutine and initialize subroutines, use the data_container module.
The problem is that after the arrays are initialized, the main subruotine, does not see the initialization of the array:
module data_container
real (8), dimension (:), allocatable:: A
end module data_container
subroutine initialize
use data_container
allocate (A(10))
end subroutine initialize
recursive subroutine main_subroutine
use data_container
call initialize
end subroutine main_subroutine
The real program is more complicated and the array is a complex data type.
Alireza
Alireza_Forghani
Sorry, my bad. I was including an older modules folder when compiling the main_subroutine code.
John_Campbell
New Contributor II
The following modified example might demonstrate a successful allocation.
 integer, parameter :: dp = selected_real_kind (14)
 real (kind=dp), dimension (:), allocatable :: A
use data_container
 write (*,*) '  initialise     : A is allocated = ',allocated (A)
 if ( allocated (A) ) then
   write (*,*) 'A is already allocated ??'
 else
   allocate (A(10))
 end if
recursive subroutine main_subroutine       !  why recursive ?
use data_container
 write (*,*) ' main_subroutine : A is allocated = ',allocated (A)
 call initialize
Program Alloc_test
use data_container
 write (*,*) 'Alloc_test       : A is allocated = ',allocated (A)
 call main_subroutine
end
Why is main_subroutine recursive ? You don't want to use ALLOCATE if the array is already allocated.
