29284 Discussions
Allocatable character array gets corrupted in the namelist
abhimodak
Hi
It seems that while integer and real allocatable arrays are fine with namelist in version 11.1.046, the allocatable character arrays still have a problem.
The snippet below has correct values for arrays I and R but the character array changes to undefined pointer/array if the length of character is greater than or equal to 5. If it is less than 5 then the debugger shows undefined address.
Abhi
Program Test_Namelist
Implicit None
Integer, Allocatable :: I(:)
Real, Allocatable :: R(:)
Character(1), Allocatable :: C(:)
NameList /Test/ I, R, C
Integer, Parameter :: Linp = 71, nMax = 5
Integer :: n
Allocate(I(nMax), R(nMax), C(nMax))
I = 0; R = 1.0; C = ' '
Open(Linp, File='Test.inp', Form='Formatted', Status='Old')
Rewind(Linp)
Read(Linp,NML=Test)
Close(Linp)
Print *, I
Print *, R
Print *, C
End Program Test_Namelist
The contents of Test.inp:
&Test
I = 1, 2, 3
R = 2.0, 3.0
C = 'A', 'B', 'C', 'D'
Steven_L_Intel1
Thanks - I can reproduce this and will report it to development. Issue ID is DPD200140845
abhimodak
FYI: This seems to be working in 11.1.054!
Abhi
Steven_L_Intel1
Indeed - haven't gotten to updating the threads yet. Glad to hear it.
xlevaill
I still have a problem with intel 11.1.056 for characters array.
When reading namelist (with the exemple below), I have a error message of "SIGSEGV, segmentation fault occurred".
When writing namelist, I have ugly symbol into characters array.
Everything is fine with REAL and INT. I attached my test files.
Any ideas ?
Xavier
Just for information :
Intel Fortran IA-64 Compiler Professional for applications running on IA-64, Version 11.1 Build 20090827 Package ID: l_cprof_p_11.1.056
Copyright (C) 1985-2009 Intel Corporation. All rights reserved
UPDATE :
The segmentation faultduring the reading was due to a delimiter problem. so the reading almost works. the segmentation fault occurs when I print the characters array. Now the character arrays contains ugly symbol or piece of code... wired ?!
IDZ_A_Intel
Hi Xavier
With the program snippet attached, I neither get a segmentation fault nor the character arrays contain ugly symbol. I am using WinXP64 with VS2005 and the compiler version is 11.1.054.
Abhi
Steven_L_Intel1
xlevaill is using the Linux compiler, where the version numbers are different. 11.1.056 is the "Update 3" compiler. This issue was resolved in Update 4.
xlevaill
Steve,
thank you for your quick answer. I 'll ask my sysadmin to install...
Xavier
xlevaill
Hi Steve,
A little question : compilation (see lines below) doesn't work with "-stand f03" option, The use of allocatable array into namelist is a F2003 feature, isn't it ?
Xavier
=== test file ===
PROGRAM MAIN
REAL, DIMENSION(:), ALLOCATABLE :: TAB
NAMELIST/TOTO/TAB
END PROGRAM MAIN
Steven_L_Intel1
Thanks. This should compile without warnings if F2003 standards checking is in effect. For F95/F90, a warning is appropriate but the wording of the warning given is incorrect. I have escalated this as issue DPD200150685.
Steven_L_Intel1
The warning will be fixed in a future release of the compiler.
