29281 Discussions
Allocate with STAT of a very large array on Mac outputs an internal error message with -i8
Cross__Mat
$ uname -a
Darwin lion.nag.co.uk 11.2.0 Darwin Kernel Version 11.2.0: Tue Aug 9 20:54:00 PDT 2011; root:xnu-1699.24.8~1/RELEASE_X86_64 x86_64
$ ifort -V
Intel Fortran Intel 64 Compiler XE for applications running on Intel 64, Version 12.1.1.246 Build 20111011
$ cat big_alloc.f90
real, Allocatable :: x(:,:)
integer d, m, alloc_stat
d = int(1.6*huge(1)**0.25)
m = (d+1)*(d+2)/2 + 2
Allocate (x(d,m),Stat=alloc_stat)
end
$ ifort -i8 big_alloc.f90 ; ./a.out
a.out(81731) malloc: *** mmap(size=1371091381248000) failed (error code=12)
*** error: can't allocate region
*** set a breakpoint in malloc_error_break to debug
alloc_stat is correctly set as /= 0, so this is just a bit unsightly really.
It doesn't seem to happen on Linux.
I'm not really a Mac user, so I'm not sure what other info to send that would be helpful!
mecej4
I am not a Mac user, either, so this is just a guess: the message is probably from the underlying C library rather than from the Intel Fortran runtime. Sometimes there is an environmental variable that can be set to control messages from MALLOC and even to control subsequent action.
jimdempseyatthecove
Mat,
The problem is:
with default integer(4) huge(1) == 2147483647
d becomes 344, n becomes 59687
x(344,59687) * 4 = 82,129,312 bytes
with default integer(8) huge(1) ==9223372036854775807
d becomes 88174, n becomes 3887459402
x(88174,3887459402) * 4 =1,371,091,381,247,792 bytes
Jim Dempsey
mecej4
Jim, your estimate is
which, when rounded up, matches the value in the MALLOC error message,
This is about 1.4 petabytes.
Cross__Mat
It's unfortunate though that it gets exposed like this. Wouldn't you expect the compiler to trap and control the subsequent action itself?
Cross__Mat
Thanks. I'm expecting the allocation to fail. The problem is that there's a nasty error message bubbling up from the guts of _somewhere_.
jimdempseyatthecove
It is bubling up from the C Runtime Library in the malloc function.
This is not an Intel Visual Fortran issue. It is an issue with the C Runtime Library as it interfaces with the O/S. In your case this is the MAC O/S. Consult with/on the MAC forums relating to too large of allocations causing error trap as opposed to returning NULL.
Jim Dempsey
