Allocating large arrays in 64-bit
Simon_Geard
I'm having trouble understanding the rules associated with allocating large arrays. The code below shows what I'm trying to do and what assumptions I'm making. The compiler output is
ifort 64.f90  /warn:all /debug:all /heap-arrays:100
Intel(R) Visual Fortran Intel(R) 64 Compiler XE for applications running on Intel(R) 64, Version 13.0.1.119 Build 20121008
Copyright (C) 1985-2012 Intel Corporation.  All rights reserved.
Microsoft (R) Incremental Linker Version 10.00.40219.01
Copyright (C) Microsoft Corporation.  All rights reserved.
-out:64.exe
-debug
-pdb:64.pdb
-subsystem:console
64.obj
[fortran]
! ifort 64.f90 /4I8 /warn:all /debug:all /heap-arrays:100
!      allocation succeeded (correct)
!      allocation failed (correct)
!      allocation failed (error)
! ifort 64.f90 /warn:all /debug:all /heap-arrays:100
!      allocation succeeded (error)
program eight_byte_array
    implicit none
    ! Variables
    integer(kind=4), allocatable :: iarray(:)
    integer(kind=4) :: isize,iostatus
    integer(kind=8), allocatable :: bigarray(:)
    integer(kind=8) :: bigsize
    isize = 2**31-1
    allocate(iarray(isize),stat=iostatus) ! Should succeed because iarray is integer(4)
    if (iostatus == 0 .and. isize == size(iarray)) then
        write(*,'(a)') 'allocation succeeded (correct)'
    else
        write(*,'(a)') 'allocation failed (error)'
    end if
    deallocate(iarray)
    bigsize = 2**32+1
    allocate(iarray(bigsize),stat=iostatus) ! Should fail because iarray is integer(4)
    if (iostatus == 0 .and. bigsize == size(iarray)) then
        write(*,'(a)') 'allocation succeeded (error)'
    else
        write(*,'(a)') 'allocation failed (correct)'
    end if
    allocate(bigarray(bigsize),stat=iostatus) ! Should succeed because bigarray is integer(8)
    if (iostatus == 0 .and. bigsize == size(bigarray)) then
    else
    end if
end program eight_byte_array
[/fortran]
Mark_Lewy
Valued Contributor I
1) Be aware that the Fortran standard specifies that integer expressions evaluate with the default integer kind, unless you explicitly specify the kind, so when you compile with the default (32-bit) integer kind you should write the expression to assign bigsize as bigsize = 2_8**32 + 1_8, otherwise bigsize will be set to 1.
2) The return value for size without a kind argument is of default integer kind; you want to use size(iarray, kind = 8) to return an integer(8) value.
Simon_Geard
Thank you. That explains the difference the /4I8 switch was making. It doesn't explain why the final allocation is failing even if I set bigsize to be the same as isize.
[fortran]
  ! ifort 64.f90 /heap-arrays:100
!      allocation failed (error): 41
    implicit none
    ! Variables
    integer(kind=4) :: isize, a_status
    isize = 2**31-1
    allocate(iarray(isize),stat=a_status) ! Should succeed because iarray is integer(4)
    if (a_status /= 0) then
        write(*,'(a,i0)') 'allocation failed (error): ',a_status
    else
        if (isize == size(iarray)) then
        else
            write(*,'(a,i0,2(a,z8.8))') 'allocation size mismatch (error): ',a_status,' ',isize,' ',size(iarray)
        end if
        deallocate(iarray)
    end if
    bigsize = 2_8**31-1_8
    allocate(bigarray(bigsize),stat=a_status) ! Should succeed because bigsize is the same as isize
    else
        if (bigsize == size(bigarray, kind=8)) then
        else
            write(*,'(a,i0,2(a,z16.16))') 'allocation size mismatch (error): ',a_status,' ',bigsize,' ',size(bigarray,kind=8)
        end if
        deallocate(iarray)
    end if
[/fortran]
outputs
Mark_Lewy
Error 41 is insufficient virtual memory: remember that as iarray is already allocated, taking up 16 GB memory, your allocation of bigarray will take memory requirements up to 48 GB.  How much physical memory and page file do you have?
Simon_Geard
Yes I failed to consider the size of the array elements (8) in this case although iarray is explicitly deallocated (line 21) so it shouldn't still be hanging around. I have 8GB physical memory and a pagefile limit of 16GB.
I have now  been able to get a c++ and Fortran program to product the same results so I think I understand what is going on. Thanks again for your help.
[fortran]
    implicit none
    integer(kind=4) :: a_status
    integer(kind=4), allocatable :: bigarray(:)
    bigsize = 2_8**31+1
    allocate(bigarray(bigsize),stat=a_status, source=0)
        write(*,'(a)') 'allocation failed'
    else
        write(*,'(z8.8)') bigsize
    end if
[/fortran]
[cpp]
#include <vector>
#include <iostream>
using namespace std;
int main(int, char**) {
    vector<int> iv;
    try {
        iv.assign((1LL<<31)+1, 0);
        cout << hex << iv.size() << endl;
    } catch (...) {
        cout << "allocation failed" << endl;
    return 0;
[/cpp]
