Dear All,
I was wondering if the issue of allocatable,
deferred-length character variables in namelist has
been finally solved in most recent versions of
ifort.
I think the issue was brought up back in 2016
(there might be some post on some Intel forum)
and Steve Lionel promptly replied and confessed
such request was lukewarmly received by the standard
committed and later dismissed.
It would be nice to have this feature
(character(len=:),allocatable allowed in namelist)
thoroughly supported by the compiler.
Enclosed at the bottom of this note you can find a
code snippet with its associated log.
The code would compile with the following
activated:
character(len=:) , allocatable :: AllIsStoredHere,TempStuff
but would error immediately.
This is the ifort version I have been running:
[cabbonda@descartes TestNamelist]$ ifort --version ifort (IFORT) 18.0.0 20170811 Copyright (C) 1985-2017 Intel Corporation. All rights reserved.
This is the log of the code when the declaration
is turned off.
[cabbonda@descartes TestNamelist]$ TestNamelist.e ~o^o~~o^o~~o^o~~o^o~~o^o~~o^o~~o^o~~o^o~~o^o~~o^o~~o^o~~o^o~ Namelist iostat = 0 ~o^o~~o^o~~o^o~~o^o~~o^o~~o^o~~o^o~~o^o~~o^o~~o^o~~o^o~~o^o~ &DEFINEDIRS ALLISSTOREDHERE = EccoRespiroAppena , TEMPSTUFF = TuCheLeVanitaConoscestiDelMondo / ~o^o~~o^o~~o^o~~o^o~~o^o~~o^o~~o^o~~o^o~~o^o~~o^o~~o^o~~o^o~ Deferred-length Character = MiaMadreAveaUnaPoveraAncella ... and its length ... 28 ~o^o~~o^o~~o^o~~o^o~~o^o~~o^o~~o^o~~o^o~~o^o~~o^o~~o^o~~o^o~
I would appreciate if you could provide some insight into the matter.
Thanks in advance for your help,
-claudio
And here you can find the code snippet:
program TestNamelist
implicit none
integer :: inml, iErr
logical :: lErr
character(len=50) :: AllIsStoredHere,TempStuff
!character(len=:) , allocatable :: AllIsStoredHere,TempStuff
character(len=:) , allocatable :: DoesThisWork
namelist /DefineDirs/ AllIsStoredHere,TempStuff
open(newunit=inml,&
file='TestThisNamelist.nml',&
status='unknown',&
iostat=iErr)
write(unit=*,fmt='(/,a)') ' ~o^o~~o^o~~o^o~~o^o~~o^o~~o^o~~o^o~~o^o~~o^o~~o^o~~o^o~~o^o~'
write(unit=*,fmt='(a,1x,i2)') ' Namelist iostat = ' , iErr
write(unit=*,fmt='(a,/)') ' ~o^o~~o^o~~o^o~~o^o~~o^o~~o^o~~o^o~~o^o~~o^o~~o^o~~o^o~~o^o~'
! Read nml
read(unit=inml,nml=DefineDirs)
! Print nml to stout
write(unit=*,nml=DefineDirs)
!Let's automatically allocate this string
DoesThisWork= 'MiaMadreAveaUnaPoveraAncella'
write(unit=*,fmt='(a,1x,a)') ' Deferred-length Character = ',DoesThisWork
write(unit=*,fmt='(a,1x,i5)') ' ... and its length ... ',len(DoesThisWork)
end program TestNamelist
!Content of the File TestThisNamelist.nml
!$DefineDirs
!AllIsStoredHere = 'EccoRespiroAppena'
!TempStuff = 'TuCheLeVanitaConoscestiDelMondo'
!$end
Assuming that I have understood your question correctly: I am using Intel ifort 18.0.2.185 Build 20180210, and the allocatable characters seems to work inside namelists. All I needed to add was to allocate the two character variables prior to reading them from the namelist. Once read, one can trim and reallocate them properly to contain only the relevant characters (This trimming approach could be problematic for charatcer variables that contain trailing blanks, though). Here is the modified code:
implicit none
logical :: lErr
!character(len=50) :: AllIsStoredHere,TempStuff
open(newunit=inml,&
status='unknown',&
iostat=iErr)
! allocate character variables:
allocate( character(1023) :: AllIsStoredHere )
allocate( character(1023) :: TempStuff )
! Read nml
AllIsStoredHere = trim(adjustl(AllIsStoredHere))
TempStuff = trim(adjustl(TempStuff))
!$DefineDirs
!$end
and here is the output:
>a.out ~o^o~~o^o~~o^o~~o^o~~o^o~~o^o~~o^o~~o^o~~o^o~~o^o~~o^o~~o^o~ Namelist iostat = 0 ~o^o~~o^o~~o^o~~o^o~~o^o~~o^o~~o^o~~o^o~~o^o~~o^o~~o^o~~o^o~ &DEFINEDIRS ALLISSTOREDHERE = EccoRespiroAppena, TEMPSTUFF = TuCheLeVanitaConoscestiDelMondo / ~o^o~~o^o~~o^o~~o^o~~o^o~~o^o~~o^o~~o^o~~o^o~~o^o~~o^o~~o^o~ Deferred-length Character = MiaMadreAveaUnaPoveraAncella ... and its length ... 28 ~o^o~~o^o~~o^o~~o^o~~o^o~~o^o~~o^o~~o^o~~o^o~~o^o~~o^o~~o^o~
