- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Hi all,
I am pleased to join this very active Intel fortran forum and posting my first issue here.
The problem is related to deallocation of the allocated arrays. The same code works seemingly fine on Mac OS X, but fails to execute successfully on Linux. Herewith I enclose the code which is giving problem. The code is basically for interfacing dstegr, a LAPACK routine.
I debug the code as following:
1) First I set ulimit -s unlimited
2) I compile the code as
ifort lapack_dstegr.f90 test_dstegr.f90 -llapack -lblas -g -traceback -warn all -check all
3) By simple ./a.out, it hangs
4) So I checked with gdb
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/x86_64-linux-gnu/libthread_db.so.1".
Linear dimension of the matrix 100
Program has been run successfully
Number of eigenvalues: 100
Selected eigenvalues
6.473654E-01 3.540588E+00 8.517578E+00 1.550983E+01
Program received signal SIGSEGV, Segmentation fault.
0x00002aaaabe94c6c in __GI___libc_free (mem=0x6c6ca0) at malloc.c:2945
2945 malloc.c: No such file or directory.
I also checked with the gfortran which is suggesting that there is some problem in deallocation of the allocated arrays "w" and "subdiag" in test_dstegr.f90 at 92 and 96 line, respectively. However, I don't see any problem at these place as I have checked that the arrays "w" and "subdiag" are allocated before the deallocations occur. So this problem seems ambiguous for me. I would appreciate very much if some one shed light on this issue.
コピーされたリンク
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
I suggest that you try "-mkl" in place of "-llapack -lblas" first. I ran your program on Windows using IFort and MKL, and the program completed execution with no error messages.
Another suggestion is that when an ALLOCATE statement fails you print a message and terminate the program, instead of simply printing a message and calling a Lapack routine with an unallocated array argument.
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Thanks mecej4 for your kind response. As I said, the same code and with the same compilation procedure do not give any error on Mac OS X platform too. I don't think -mkl will help and it is indeed the case as I have verified on LINUX. Also, I don't get any clear error message of the failure of allocation or deallocation. However, somewhat it is indicating a memory issue. I am waiting responses of other people who can check the code on LINUX, say, Ubuntu, CentOS, RED HAT, etc. I am getting problem in Ubuntu, CentOS where I have checked my code.
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
It would be useful to know the particulars of the BLAS and Lapack libraries that are giving you trouble on Linux.
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
@mecej4: I am calling DSTEGR subroutine.
http://www.netlib.org/lapack/explore-html/d0/d3b/dstegr_8f.html
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
I think that you misunderstood my request.
Did you download prebuilt Lapack and BLAS libraries and runtime as a package from your Linux distribution repository, or from somewhere else? Did you build them from source yourself and, if so, using which compiler? Are you using a static library or a shared library?
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
@mecej4: Sorry I did not get your point. I am using system (or LINUX distribution) libraries and so should be shared. I'm not sure about it. On locate lapack, I am getting
/usr/lib/lapack
/usr/lib/liblapack.a
/usr/lib/liblapack.so
/usr/lib/liblapack.so.3
/usr/lib/liblapack.so.3gf
/usr/lib/lapack/liblapack.a
/usr/lib/lapack/liblapack.so
/usr/lib/lapack/liblapack.so.3
/usr/lib/lapack/liblapack.so.3.0
/usr/lib/libblas
/usr/lib/libblas.a
/usr/lib/libblas.so
/usr/lib/libblas.so.3
/usr/lib/libblas.so.3gf
/usr/lib/libgslcblas.so.0
/usr/lib/libgslcblas.so.0.0.0
/usr/lib/libblas/libblas.a
/usr/lib/libblas/libblas.so
/usr/lib/libblas/libblas.so.3
/usr/lib/libblas/libblas.so.3.0
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
If the question is one of Intel Fortran correctly working with a standard Linux library, it would be appropriate to this forum. However, the problem that you described occurs even when you use Gfortran in place of Ifort. Therefore, the problem is related to one of two possibilities: (i) An error in the rather complicated argument list to DSTEGR(), including allocation of the arrays in that list; (ii) An error in the library subroutine itself (an unlikely third possibility is bugs in Lapack routines).
Neither of these problems is interesting enough to induce me to investigate further. Furthermore, one of your two files implements a Fortran 95 interface to the Fortran 77 routine DSTEGR, which is a bit of "reinventing the wheel", since Lapack95 contains an even better interface (see the MKL manual page for ?STEGR).
If, however, all that you want is to run test calculations with a minimum of fuss, here is a replacement for your driver program, using facilities provided by MKL. The main change is the call on line 52. To compile, use "ifort -mkl test_dstegr.f90 -lmkl_lapack95". This program runs through the entire range of k provided without any errors.
program test_lapack_dstegr
use mkl95_lapack
implicit none
! .. parameters ..
integer, parameter :: dp = selected_real_kind (14)
! .. main variables ..
integer :: dim
real (kind=dp), dimension (:), allocatable :: diag
real (kind=dp), dimension (:), allocatable :: subdiag
! .. lapack variables ..
character (len=1) :: jobz = 'v'
character (len=1) :: range = 'a'
integer :: m
real (kind=dp), dimension (:), allocatable :: w
real (kind=dp), dimension (:,:), allocatable :: z
integer :: info
! .. other variables ..
integer :: i, j, k, err, ios
real (kind=dp) :: time,t_initial, t_final
open(unit=11, file="time_dstegr.data", iostat=ios, status="replace")
if ( ios /= 0 ) stop "error opening file time_dstegr.data"
write (11,'(1x,2(a12,2x))') "dim", "time"
do k = 100, 4000, 100
! .. dimension of matrix ..
dim = k
print *, "Linear dimension of the matrix", dim
! .. allocate arrays ..
allocate(diag(dim), stat=err)
if (err /= 0) print *, "diag: allocation request denied"
allocate(subdiag(dim), stat=err)
if (err /= 0) print *, "subdiag: allocation request denied"
! .. storing matrix elements of the upper triangular part ..
do i = 1, dim, 1
diag(i) = real(i*i, dp)
if ( i < dim ) subdiag(i) = real(i, dp)
end do
! .. variables for lapack routine dstegr ..
allocate(w(dim), stat=err)
if (err /= 0) print *, "w: allocation request denied"
allocate(z(dim,dim), stat=err)
if (err /= 0) print *, "z: allocation request denied"
call cpu_time(t_initial)
call rstegr (diag,subdiag,w,z=z,m=m,abstol=1d-12,info=info)
call cpu_time(t_final)
time=t_final-t_initial
write(*,*)'info = ',info
if(info.ne.0)stop
select case (info)
case (0)
print *, "Program has been run successfully"
print *, "Number of eigenvalues: ", m
print *, "Selected eigenvalues"
print '(1x,4(es13.6,1x))', (w(i), i=1,4)
if ( jobz == 'v' .and. dim <= 4) then
print *, "Selected eigenvectors"
print '(9x,4(i13,1x))', (i,i=1,m)
do i = 1, dim, 1
print '(1x,i4,4x,4(es13.6,1x))', i, (z(i,j),j=1,m)
end do
end if
case (:-1)
print '(1x,a,1x,i2,a)', "The", abs(info),"th argument in &
& dstegr routine had an illegal value"
case default
print *, "internal error"
end select
if (allocated(z)) deallocate(z, stat=err)
if (err /= 0) print *, "z: deallocation request denied"
if (allocated(w)) deallocate(w, stat=err)
if (err /= 0) print *, "w: deallocation request denied"
if (allocated(diag)) deallocate(diag, stat=err)
if (err /= 0) print *, "diag: deallocation request denied"
if (allocated(subdiag)) deallocate(subdiag, stat=err)
if (err /= 0) print *, "subdiag: deallocation request denied"
! .. timing benchmark ..
write (11, '(1x, i13, 1x, es13.6)') dim, time
end do
close(unit=11, iostat=ios)
if ( ios /= 0 ) stop "error closing file unit 11"
end program test_lapack_dstegr
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
The problem is dstegr routine runs successfully and gives info=0, and program stuck when deallocation of w and subdiag arrays occur. Strangely this happens only on Linux platform not on Mac OS X and Windows. Just for curiosity, I would like to know what is wrong with my code which makes it incompatible with Linux.
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
You have some incorrect logic in your allocation/deallocation routines. Here is an example:
if (allocated(work)) deallocate(work, stat=err)
if (err /= 0) print *, "work: deallocation request denied"
The problem is that if 'work' is not presently allocated, 'err' will be undefined after the first of these two lines has been executed. This undefined variable will be tested in the next line, giving you misleading messages (or not printing when it should).
Of course, this error is a side issue not related to your main complaint.
I found that by updating the Lapack library to 3.5.0, the problems regarding access violation, heap corruption, etc., went away. Have you updated the Lapack and BLAS libraries on your Linux system recently?
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
I compiled lapack and blas libraries from source lapack-3.5.0 with ifort on Linux system, and then used these libs in my code. Unfortunately, I got the same result as before. I mean gdb gives
0x00007ffff736fc6c in __GI___libc_free (mem=0x6edd80) at malloc.c:2945
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
F.R.: I believe that your program exposes a bug in the standard library routine free(). I tracked down the problem by using an assembly level debugger, and have reported the bug at https://bugzilla.novell.com/show_bug.cgi?id=891349 . However, I am not confident about my knowledge in matters related to the GCC runtime, and there is an obstacle to overcome. Bugzillas usually ask for "steps to reproduce" an error, and I don't know how to put together a program that generates a valid address which also has at least one of bits 26-63 set.
Followup: I was able to create a pared down Fortran program from your code to exhibit the bug. I have posted it in a new post at https://software.intel.com/en-us/forums/topic/520237 . Thanks for your patience and cooperation in making this happen.
