Ambiguous generic interface
Blane_J_
Hi, everyone. The following code puzzles me:
module test
    type :: tp
        private
        integer :: i
    contains
        private
        generic, public :: ge => sub1,  &
                                 sub2
        procedure, pass :: sub1
        procedure, pass :: sub2
    end type tp
    contains
    subroutine sub1(this, s)
        class(ab), intent(in) :: this
        class(*),  intent(in) :: s
    end subroutine sub1
    subroutine sub2(this, s)
        integer,   intent(in) :: s
    end subroutine sub2
end module test
And the compiler says:
Ambiguous generic interface GE: previously declared specific procedure SUB1 is not distinguishable from this declaration. [SUB2]
Is it a problem to distinguish INTEGER from unlimited polymorphic ?
Arjen_Markus
Sure it is possible, but you need an additional argument to solve the ambiguity.
Arjen_Markus
Perhaps the other way around: an unlimited polymorphic variable can have any type, so indeed it can not be distinguished by type alone.
Blane_J_
SO it's not possible to have sub/funcs which have unlimited polymorphic argument in overloaded generics ?
Arjen_Markus
Blane_J_
Thanks I got it.
