29386 Discussions
An ICE with ifort (IFORT) 2021.5.0 20211109 using coarray=shared compiler flag
jdelia
Dear developers,
Apologies in advance because I'm a new user in this forum and I don't know if this is the right place to report a Software Problem Report.
Below there is a simple session with a reduced test case (please see attached file) that produces an Internal Compiler Error (ICE) with the ifort compiler using Fedora 35 on a x86_64-pc-linux-gnu machine, but it is ok with the gfortran one.
Regards.
Jorge.
$ cat /proc/cpuinfo
  Intel(R) Core(TM) i7-2630QM CPU @ 2.00GHz
$ cat /proc/version
Linux version 5.15.16-200.fc35.x86_64 (mockbuild@bkernel01.iad2.fedoraproject.org) (gcc (GCC) 11.2.1 20211203 (Red Hat 11.2.1-7), GNU ld version 2.37-10.fc35) #1 SMP Thu Jan 20 15:38:18 UTC 2022
$ which ifort
/opt/intel/oneapi/compiler/2022.0.2/linux/bin/intel64/ifort
$ ifort --version
Copyright (C) 1985-2021 Intel Corporation. All rights reserved.
$ ifort -c -coarray=shared -std18 -O0 -warn all -WB -Winline bug-ice-03.f90
bug-ice-03.f90(6): warning #5268: Extension to standard: The text exceeds right hand column allowed on the line.
! Linux version 5.15.16-200.fc35.x86_64 (mockbuild@bkernel01.iad2.fedoraproject.org) (gcc (GCC) 11.2.1 20211203 (Red Hat 11.2.1-7), GNU ld version 2.37-10.fc35) #1 SMP Thu Jan 20 15:38:18 UTC 2022
bug-ice-03.f90(42): catastrophic error: **Internal compiler error: internal abort** Please report this error along with the circumstances in which it occurred in a Software Problem Report. Note: File and line given may not be explicit cause of this error.
compilation aborted for bug-ice-03.f90 (code 1)
$ which mpifort
/usr/beta/openmpi/bin/mpifort
$ mpifort --version
GNU Fortran (GCC) 12.0.0 20220101 (experimental)
Copyright (C) 2021 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
$ mpifort -c -march=native -mtune=native -fall-intrinsics -fargument-alias -fautomatic -fcoarray=lib -fimplicit-none -fmax-errors=4 -fPIC -std=f2018 -Wall -Waliasing -Warray-temporaries -Wcharacter-truncation -Werror -Wextra -Wimplicit-interface -Wimplicit-procedure -Wintrinsic-shadow -Wline-truncation -Wrealloc-lhs-all -Wsurprising -Wtabs -Wunused-parameter -Wuninitialized -Wunsafe-loop-optimizations -O3 bug-ice-03.f90
Barbara_P_Intel
This ICE is fixed in the Fortran compilers, ifort 2021.7.0 and ifx 2022.2.0, that were released earlier this month. Both compilers are available as part of the oneAPI HPC Toolkit.
Give it a try!
Barbara_P_Intel
Thank you for reporting this ICE. I filed a bug report on your behalf, CMPLRIL0-34546. I'll let you know when it's fixed.
jdelia
Dear Barbara: ok, I will look forward to hearing from you when it is fixed. Thanks! Regards. Jorge.
Barbara_P_Intel
Give it a try!
