29386 Discussions
An error with FOR_DESCRIPTOR_ASSIGN subroutine
Tetsuzin
Hi, I'm using intel fortran compiler 10.1.13 and VS2005 and I currently have a problem in using FOR_DESCRIPTOR_ASSIGN subroutine. Take a look on this simply example:
use ifcore
implicit none
integer(4), pointer :: a(:)
integer(4), allocatable::buffer(:)
type(FOR_DIMS_INFO) dims_info(1)
integer::i, N
N=10
allocate(buffer(1:N))
do i=1,N
buffer(i)=i
enddo
dims_info(1)%LOWERBOUND = 0
dims_info(1)%UPPERBOUND = N-1
dims_info(1)%STRIDE = 1
call FOR_DESCRIPTOR_ASSIGN(&
a, &
LOC(buffer(1)), &
4, &
FOR_DESCRIPTOR_ARRAY_DEFINED .or. &
FOR_DESCRIPTOR_ARRAY_NODEALLOC .or. &
FOR_DESCRIPTOR_ARRAY_CONTIGUOUS, &
1, &
dims_info)
print *,a(0)
end
The resuls of this programm is:
forrtl: severe (408): fort: (3): Subscript #1 of the array A has value 0 which is less than the lower bound of 1
But lower bound of a must be 0 and upper bound must be 9
What do I do wrong?
PS. Sorry for my English.
Tetsuzin
Well, I think I am doing everything right and this is BUG offortran compiler.
The same error on x64 platform.
There is more than just the bounds being wrong - the array location is wrong too. I'll analyze this and see what is going on.
It is just the bounds - no matter what you say for the lower bound, it sets the descriptor lower bound to 1. I'll report this to the developers.
Tetsuzin
Thank you for help and analyze. I'll be waiting for the compiler updates.
I would recommend that you submit a problem report to Intel Support and reference T83625-CP. I can probably come up with an alternative for you in the next couple of days.
