29274 Discussions
An internal compiler error relating to abstract interface and submodule
Niranama
I would like to report a possible bug in the Intel Fortran compilers (both IFORT and IFX - version 2024.0.0) that relates to an abstract interface and submodule inheritance.
The attached code causes an internal compiler error.  The problem appears to be relating to the callback procedure argument of the 'Proc_Engine_II' routine in the 'SubMod2' submodule.
Three workarounds that seem to solve the ICE problem are:
(1) Putting the 'Proc_Main_II' and 'Proc_Engine_II' routines in the 'SubMod1' submodule instead of the 'SubMod2' submodule.
(2) Define another abstract interface for the callback routine in the 'SubMod2' submodule (which is exactly the same as the one in the 'ModMain' module) and then use this abstract interface instead.
(3) Do not use the 'SubMod1' module as a parent submodule of the 'SubMod2' module.
However, in practice, these three workarounds would cause redundancy problems and/or very large file(s).
Ron_Green
Thank you for the simple reproducer. The bug ID is CMPLRLLVM-57905
Devorah_H_Intel
The fix for this issue will be available in 2025.1 ifx.
Niranama
Good job.  Sorry for the late reply since I just installed the latest compiler (2025.2 ifx).
However, I have another (strange) bug to report.  As shown by the attached files, the bug occurs in the SMOD_W_EXTERNAL submodule where the compiler (earlier and latest versions) reports "error #7257: The characteristics of the procedure argument differ from those specified in the separate interface body."  Nonetheless, if you comment out the DUMMY subroutine.  Then, the error disappears.  I also includes the SMOD_WO_EXTERNAL submodule to show that this bug relates to an external procedure as argument.
Niranama
