29413 Discussions
Another FORTRAN 10.1 & VS 2008 Integration Issue
jack2927
I have a new machine with VISTA. I need to move all my work over to this new machine. Installed on the machine is VS 2005 & VS 2008. I also need to integrate Visual FORTRAN to both developer studios.
When I install everything seems to be fine. When I go to the Control Panel to access the program Intel Fortran Compilor 10.1 Integrations in Microsoft Studio, I am only allowed to integrate it into VS 2005. Integrating into 2008 is NOT an option for me.
I have read your article about missing folders and that was the case here. Idid the repair fix on your page and that seems to fix the missing file. However I can still not integrate the FORTRAN with 2008.
When I bring up VS 2005, I see all the normal references to FORTRAN. When I bring up VS 2008 I see a FORTRAN Help item, but noother integration.
I am totally lost here and have wasted a huge amount of time. If this doesnt get resolved I could lose my job. Please help.
You need at least 10.1.019 for VS2008 support. This was an update after the initial release of 10.1. Which exact version are you using?
I recommend using the latest compiler version available to you. 11.1 is the current version.
