Another (!) bug with IMPORT
OP1
New Contributor III
As shown, the following code does not compile with ifx 2026.0.0 (Debug and Release) on Windows.
MODULE M
IMPLICIT NONE
TYPE :: T
    CONTAINS
    PROCEDURE, NOPASS :: S => T_S
    ! PROCEDURE, NOPASS :: SOME_OTHER_BINDING_NAME => T_S
END TYPE T
INTERFACE
    MODULE SUBROUTINE T_S
    END SUBROUTINE T_S
END INTERFACE
END MODULE M
MODULE N
IMPLICIT NONE
INTERFACE
    MODULE SUBROUTINE S
    END SUBROUTINE S
END INTERFACE
END MODULE N
SUBMODULE (N) S
USE :: M, ONLY : T
IMPORT, ALL
IMPLICIT NONE
CONTAINS
MODULE SUBROUTINE S
END SUBROUTINE S
END SUBMODULE S
The compiler erroneously claims that on line 26:
error #8847: A use-associated entity from module M conflicts with a host-associated entity explicitly made accessible by an IMPORT statement in the same scope.   [S]
 This does not make any sense at all, since S is simply a binding name for a procedure bound to the derived type T.
The code will compile if you comment out line 5 and uncomment line 6 (essentially, using a different binding name that does not "collide" with S).
Or, the code will compile if lines 5 and 6 are left as they are and line 25 is commented out.
