29651 Discussions
Another -e03 question with derived data types and C
breitenfeld
I have the following program
PROGRAM main
USE ISO_C_BINDING
TYPE :: ir
INTEGER(C_INT) :: int_scalar
REAL(C_FLOAT) :: real_scalar
END TYPE ir
TYPE(ir), TARGET :: derivedtype
TYPE(C_PTR) :: f_ptr
f_ptr = C_LOC(derivedtype)
END PROGRAM main
and if I compile with -e03 it does not give any warnings. I thought for a derived type to be interoperable as defined by the standard it has to have a BIND(C)
TYPE, BIND(C) :: ir
What am I missing, does this code without the bind(C) conform to the standard? Or is this another situation where "don't have a good way of enforcing the standard's requirement of an interoperable type."
In other words, the -e03 flag in general will not check if X in C_LOC(X) is interoperable, and does not produce a warning even if X is not interoperable and violates the standard.
The code does not conform, but the compiler is not required to diagnose this.
reinhold-bader
New Contributor II
I think that the code, as it stands, is standard conforming. While the derived type is not interoperable, the c_loc() intrinsic does accept scalars of non-interoperable type. This is the mechanism provided to pass a handle to non-interoperable data through C - so if you misuse this handle, this would either happen on the C side of things (on which the compiler has no influence), or because unpacking the handle with c_f_pointer() is performed incorrectly (which the compiler typically cannot diagnose).
On a reread, I think you are correct. The argument to C_LOC is allowed to be "a nonpolymorphic scalar, have no type parameters and be... a nonallocatable, nonpointer variable that has the TARGET attribute", which is the case here.
breitenfeld
It does indeed seem to be standard compliant without needing the BIND(C) in light of the standard quoted. Thanks.
