29651 Discussions
Compiler warning with character*(*) function
michael_green
The following works OK ...
character*(*) function upper(string)
!Returns the upper case version of the input STRING.
implicit none
character*(*) string
character*1024 temp
integer*4 i,l
l = len(string)
temp = string
do i = 1,l
if(temp(i:i).ge.'a'.and.temp(i:i).le.'z')then
temp(i:i) = char(ichar(temp(i:i))-32)
end if
end do
upper = temp(1:l)
return
end
But the compiler warns me :
Warning: A CHARACTER function name must not be declared with an asterisk type-param-value (i.e., (LEN=*)) if the function is part of an interface-body. No interface block will be generated. [UPPER]
Can I just ignore this or is there a better way to write the function?
With many thanks
Mike
TinTin_9
Strange, I just copy-pasted your function as it is and compiled it and it gave me no warning, i even used it on a test case successfully.
Can you please post your calling program here ?
Thanks..
TimP
I take it that /gen-interfaces was set. character *(*) is one of the few things which was new in f77 which I believe is disrecommended since f90. In the present context, I believe it was not strictly legal in f77, which would take away f77 compatibility as an argument for using this syntax.
character(len=len(string)) function(string)
appears to be a legitimate equivalent (in f90), by my reading of MR&C. If this doesn't work, with or without /gen-interfaces, I think it would be worth a submission on premier.intel.com for further study.
Of course, if you're trying to find something which doesn't involve abuse of Fortran syntax, you'll also fix integer*4.
Something like
character(len=len(string)) temp
might be better, given that you are using an f90 compiler, unless you can guarantee that len=1024 will not be exceeded, and that 1024 is not an excessive extension of the string length.
This code appears to be trying to fit within f77, "except for a few exceptions," to its detriment.
Tim has it mostly right. CHARACTER(*) is fine in current Fortran for dummy arguments, but is deprecated for function declarations and it's not supported for use in interface blocks. Because new projects default to /gen-interface, the compiler wants to generate an interface for this function but can't, hence the warning.
Tim also has the right approach for a modern replacement, but using this requires an explicit interface to be visible to the caller (and a generated interface won't do.)
You could ignore the warning, or even turn off generated interface creation and checking if this is a concern to you.
michael_green
/gen-interface was not set, but it made no difference either way anyway.
The following:
character(len=len(string)) function upper(string)
does not compile. I get "The data types of the argument(s) are invalid. (LEN)"
Maybe I'll just take Steve's advice and ignore the warnings.
Many thanks
Mike
Generated interfaces had to be enabled or otherwise you would not have received that initial message. It is on by default in a newly created project. Look under Project > Properties > Fortran > Diagnostics
Jugoslav_Dujic
Valued Contributor II
michaelgreen:
The following:
Didn't test myself, but most likely it's just an issue of declaration order. The following certainly works:
character(*), intent(in):: string
character(len=len(string)):: upper
michael_green
Thanks, Jugoslav,
That certainly compiles and nearly gives the right answer, but there is a small problem that I am unable to solve. If I have:
character*20username,upper
character*128line
username = 'MichaelG'
line = 'michaelg,manager,casual,user'
i = index(line,',')
if(upper(line(1:i-1))==upper(username))found = .true.
found remains false because upper(username) = 'MICHAELG' but upper(line(1:i-1)) = 'MICHAELG#%&!!'Actually, I get Chinese characters after my name, but the point is the same. Sorry to be a pain.
Thanks for your help,
Mike
Jugoslav_Dujic
michaelgreen:
character*20 upper
Exactly: you get "MICHAELG" plus some random garbage off the stack, to make the 20 characters -- because you've just falsely declared upper to return a 20-character string. You have to have an explicit interface (best, function Upper in a MODULE) to have it work as desired.
llynisa
I have never had any problems with the following conversion routine which seems to avoid some of the problems above.
function Upc(String)
! Returns String in upper case. String itself is not converted.
use user32, only : CharUpper
implicit none
character*(*), intent(in) :: String ! Input string.
character(len(String)) :: Upc ! Function type.
integer*4 :: i ! Working variable.
Upc = String ! Set Upc to preserve String.
i = CharUpper(Upc) ! Convert String using WinAPI function.
return
end function Upc
HTH
Bear of Little Brain
