I am trying to call a subroutine in a loop. This subroutine has a local coarray. Following is the code that I am using:
! Test local coarray in procedure called in a loop.
program main
use, intrinsic :: iso_fortran_env, only : input_unit, output_unit, error_unit
implicit none
! Variable declaration.
integer :: me, ti
integer :: GHOST_WIDTH, TSTART, TSTEPS
sync all
! Initialize.
GHOST_WIDTH = 1
TSTART = 0
TSTEPS = 10000
me = this_image()
! Iterate.
do ti = TSTART + 1, TSTART + TSTEPS
call Aldeal( GHOST_WIDTH )
if ( me == 1 ) write( output_unit, * ) ti
end do
if ( me == 1 ) write( output_unit, * ) "All done!"
contains
subroutine Aldeal( width )
integer, intent(in) :: width
integer, allocatable, dimension(:), codimension[:] :: shell1_Co, shell2_Co, shell3_Co
allocate( shell1_Co(width)Right now the subroutine is not doing anything other than allocating the local coarray and deallocating it. But even while doing this, the program is throwing me the following error after some iterations:
forrtl: severe (174): SIGSEGV, segmentation fault occurred In coarray image 1 Image PC Routine Line Source coarray_main 0000000000406063 Unknown Unknown Unknown libpthread-2.17.s 00007F21D8B845F0 Unknown Unknown Unknown libicaf.so 00007F21D90970D5 for_rtl_ICAF_CO_D Unknown Unknown coarray_main 0000000000405054 main_IP_aldeal_ 36 coarray_main.f90 coarray_main 0000000000404AEC MAIN__ 22 coarray_main.f90 coarray_main 0000000000404A22 Unknown Unknown Unknown libc-2.17.so 00007F21D85C5505 __libc_start_main Unknown Unknown coarray_main 0000000000404929 Unknown Unknown Unknown Abort(0) on node 0 (rank 0 in comm 496): application called MPI_Abort(comm=0x84000003, 0) - process 0
And the same error is repeated for other images as well.
I am not able to understand what exactly I am doing wrong. Please help.
P.S. I am using Centos 7 with Intel(R) Parallel Studio XE 2019 Update 4 for Linux.
